o2 sensor problems???or something else???
Old Sep 9, 2002 | 05:59 PM
shock211's Avatar
to all the tight as$es i know what you're gonna say but before you do so, read on.....i've already been doing some searching and i can't find what i'm looking for.
newayz...
whenever i turn on my car the engine runs very rough...if i give it gas the enginge seems to choke and won't rev up..if i pesist to increase throttle a pop noise comes from the intake... i took out the air box today to see if in fact the pop was coming from the intake, and i was right...so is this the o2 sensor phukin up on me?
any help is appreciated or even if you guys can't do that at least leave me a link to a good explanation of this issue.
thanx
Old Sep 9, 2002 | 06:24 PM
RosenKen's Avatar
It sounds like it's a little more than the O2 sensor. I dunno anything about VGs, but it sounds like a fuel issue, either fuel pump or a fuel injector is FUBAR'd. Check your engine codes. I dunno how to do that either, on a VG
VE powah!
Old Sep 9, 2002 | 07:50 PM
SecretAsianMan's Avatar
Originally posted by shock211
...whenever i turn on my car the engine runs very rough...if i give it gas the enginge seems to choke and won't rev up..if i pesist to increase throttle a pop noise comes from the intake... i took out the air box today to see if in fact the pop was coming from the intake, and i was right...thanx
What you seem to be describing is a "backfire" issue into the intake system. This can be caused by a fuel mixture or timing problem, by vacuum leaks or a few other issues. It's possible your timing belt wasn't tight as$ed enough and slipped a tooth -- do you know when it was last replaced?
The oxygen sensor wouldn't be my first guess.
--SAM
Old Sep 10, 2002 | 05:39 AM
shock211's Avatar
i had it replaced 4 months ago.
Old Sep 10, 2002 | 06:57 AM
How long has the car been making these popping noises?
--SAM
Old Sep 10, 2002 | 09:36 AM
shock211's Avatar
4-6 weeks....when it started i was freaking out...but it went away for awhile...but now it's back with a vengeance and i'm freaking out again. i'm gonna get a diagnostics test done by nissan this week hopefully.
--SAM
Old Sep 10, 2002 | 09:15 PM
eric93SE's Avatar
Could be a bad throttle positioning sensor.
Old Sep 11, 2002 | 06:49 AM
shock211's Avatar
i hate this problem! so many people get it, but there's so many things that could cause it. i guess i'll have to wait and see what nissan says after the diagnostic test. actually i'm going to check the ecu for error codes as well.
i really don't trust nissan to pin point the problem.
thanx for the help people
Old Sep 13, 2002 | 01:24 PM
jrh237's Avatar
i had a problem similar to yours, i thought it was a bad fuel filter or something, i had a guy look at it and come to fingd out that it was the mas air flow sensor, big bucks new found one used though.
bbsitum
Sep 6, 2019 07:31 PM
-ReLLiK-
Apr 29, 2016 06:25 PM
ballerchris510
Sep 23, 2015 08:46 PM
