fuel injector 24 ohm
Old Sep 11, 2002 | 09:27 PM
maximalover's Avatar
fuel injector 24 ohm. A PROBLEM ??
Please don't start fuming over...me
I know and I have searched for fuel injectors. I am not sure whether it is the problem with injectors.
So.. I checked the injectors two of them read 24 ohms two weeks ago.. Other were 12 ohms
Now the symptoms
- Started running really rough now a days..
- I hear ryhtmic sound kuch kuch.. more audible loud during start
- there is a slight vibration and loss of power
- When it is hot and if I drive continously for 1 hour it starts hesistating badly
Are these good indication of Fuel injecotr failure?????
Any suggestion for next step
I wanted to check as per the FSM by removing crankshaft position sensor and then moving it the shaft... But one small screw on it rusted big time .. How do I remove it..?
As always I appreciate your feed back.. You guys have saved me money and time
Old Sep 12, 2002 | 07:29 AM
Re: fuel injector 24 ohm. A PROBLEM ??
Any one had similar problems...
Your input will help me big time
Old Sep 12, 2002 | 12:31 PM
avusblue92se's Avatar
that sounds exactly like the problem i was having. but i did not measure ohms at all. my car had to be left at home because of this and i haven't had the time to go back and get it.
Old Sep 12, 2002 | 01:49 PM
How long has it been ?
Did you get it checked by mechanic or dealer?
Has it become so bad that you can no longer drive it?
How long you have seen this problem?
I can drive right now with reduced power. When the problem occurs then that it... I am no longer in control of car.. It revs when it wants...
Old Sep 12, 2002 | 02:40 PM
i had it checked by a mechanic because i was short on time. This happened on saturday and i was going back to school on sunday. he checked it out and found nothing at all. he suggested that i try fuel injector cleaner. my car does not rev on its own, but is sluggish and shakes when the problem occurs.
jmlee44
Oct 2, 2022 02:13 PM
aw11power
Oct 10, 2021 04:57 AM
Forge277
Jun 13, 2016 09:26 PM
