Stock intake pipe question
Old Sep 14, 2002 | 11:23 PM
rupe's Avatar
Being somewhat bored this Saturday, I decided to experiment with my OSCAI a little bit. I removed the intake pipe on the non-MAF sensor side of the airbox, and was surprised to see a curved plastic tube branch off from the main intake pipe, and curve down through a hole in the body.
The tube is about a foot long, has an o-ring/rubber gasket about 6" away from the main intake tube, and is completely sealed, save for a small screw hole at the very end?
What's the function of this secondary tubing? Some sort of moisture/debris catch prior to the airbox filter?
--- Rupert
Rupert Scammell
rupe@arrow.yak.net
http://arrow.yak.net/
Old Sep 14, 2002 | 11:27 PM
DA-MAX's Avatar
Eat, sleep, and sh*t 2JZ
Re: Stock intake pipe question
I've heard it is a resonator of some sort.
--- Rupert
Rupert Scammell
rupe@arrow.yak.net
Old Sep 15, 2002 | 12:11 AM
rupe's Avatar
Interesting. The black box that's attached under the stock intake tubing on the MAF side of the airbox serves roughly the same purpose, if I remember correctly, namely noise dampening, and little (if anything?) else...
Is there any harm in trimming away the boxy resonator from the base of the pipe, then sealing the gap? If nothing else, I assume it'd make the engine sound louder?
--- Rupert
Rupert Scammell
rupe@arrow.yak.net
Old Sep 15, 2002 | 01:38 PM
skatanic28's Avatar
id think it would just help the flow, but make induction noise a little greater. just make sure whatever you seal it with isnt gonna get sucked away and destroy ur maf sensor.
Old Sep 15, 2002 | 02:01 PM
kingrye's Avatar
im pretty sure its incase some water getts in there gravity will pull it away from the maf
Old Sep 15, 2002 | 02:20 PM
DA-MAX's Avatar
how would it do that?? its a sealed and empty cylinder...
Matt93SE
May 24, 2019 02:58 PM
incubusjohnny
Nov 3, 2015 05:18 PM
Stagnet04
Sep 2, 2015 07:53 AM
MAXSE5SPD
Aug 23, 2015 12:06 PM
MaximaDrvr
Aug 19, 2015 08:20 PM
