Please Help Diagnose
Old Sep 17, 2002 | 07:47 PM
crsmax's Avatar
Just had power steering pump and high pressure power steering hose replaced again. No leaking, but sometimes hear a slight whinning from that location. Especially on startup and just turning the wheels? Could it be the belt, pulley, or pump itself?
Old Sep 17, 2002 | 08:01 PM
Sudesh's Avatar
Re: Please Help Diagnose
It could be that you're low on fluid or you have air in the system..perhaps when you had the pump and hose replaced a component like a seal or something was left out accidently. But check the fluid level first remember to use ATF and not power steering fluid, if that's cool, bleed the system of air, which is very easy jack up the front end open power steering resevoir, turn the wheels and lock it hard to one end, then hard to the other end, do this quite a few times, then start the car and do the same thing over and over, that'll get rid of the air, if any. good luck.
Old Sep 17, 2002 | 08:31 PM
92 Max's Avatar
Could also be just a loose, glazed or otherwise slipping belt. Check tightness of belt (WITH MOTOR STOPPED). There's a procedure in the book, but I just find a longer span of unsupported belt and press on it with my thumb, (may need to get under car). Belt shouldn't have more than about 1/4 to 1/2 inch deflection with a good bit of pressure. If much more, belt is loose. Don't overtighten or it leads to bearing failure on any or all belt driven components. Could be glaze from slipping. Check pulley for kind of black, glassy coat on pulley or on inside of belt. Perhaps try belt sticky spray (can't remember name, but can get at parts store).
'92 SE
Old Sep 17, 2002 | 08:59 PM
1993MaxSE's Avatar
air bubble in system
i had my power steering hose replaced last year and had the same thing happen, I took it back to the shop and they more carefully bled and filled the system and made sure no air bubble...sound went away. They did it for free of course since there's not supposed to be air bubbles right after you get it fixed!
Old Sep 18, 2002 | 08:14 AM
Jaybird180's Avatar
Re: Re: Please Help Diagnose
ATF??????
Old Sep 18, 2002 | 09:03 AM
1993MaxSE's Avatar
Re: Re: Re: Please Help Diagnose
Originally posted by Jaybird180
ATF??????
No, power steering fluid
Old Sep 18, 2002 | 09:05 AM
DA-MAX's Avatar
Eat, sleep, and sh*t 2JZ
ATF??????
yeah thats what is suggested...but I don't think there are any detrminetal effects for using PS fluid are there??
CRS I wish I could help you out bro, but I'm puzzled myself! the only time I had that prob was when my PS hose was leaking...after that was fixed the whining and noised stopped, maybe its your pump??
Old Sep 18, 2002 | 09:13 AM
male's Avatar
Re: Re: Re: Re: Please Help Diagnose
He said use ATF and NOT PS fluid. What the ...?
Old Sep 18, 2002 | 11:48 AM
crsmax's Avatar
Re: Re: Re: Re: Re: Please Help Diagnose
Thanks fellas... I guess I will jack it up this weeknd, and systematically check everythign out...
DAMAX... you available this weekend?
Old Sep 18, 2002 | 11:50 AM
DA-MAX's Avatar
Re: Re: Re: Re: Re: Re: Please Help Diagnose
yeah, check yout PMs, I'll give you my cell #!
Old Sep 18, 2002 | 12:35 PM
crsmax's Avatar
Re: Re: Re: Re: Re: Re: Re: Please Help Diagnose
Cool. Thanks.
tarun900
19
Dec 20, 2021 06:57 PM
pears
Sep 18, 2015 05:25 AM
Maxie40
Sep 14, 2015 11:28 AM
lummyrob
Sep 2, 2015 12:31 AM
Shock_and_Awe
Aug 23, 2015 01:02 PM
