Power Door lock help? (little long)
Old Sep 28, 2002 | 05:28 PM
ssjones's Avatar
Guys & Gals:
I am having difficulty with the power locks on my '89 SE. My problems started when I replaced the passenger front window regulator last month. Last week, that window would not power up. I assumed the motor went bad and pulled the panel/regulator/motor and put in another motor. Window still would not go up with either the drivers or passenger switch. I figured the switch was bad and swapped with the passenger rear switch. This worked but the up/down was now reversed on both switches. I swapped the motor leads and everything was fine. Put back the panel and took the car on an errand. Then I discover that the power lock switch on the drivers console doesn't work. Neither does unlocking with the key. My Haynes manual was worthless trying to troubleshoot. I could not actually locate on which panel the locks get power. All of the under-dash fuses are fine. I assume there is a relay somewhere, any idea where to look/replace?
Btw, if anyone needs advice replacing a window regulator or motor I'm now a wealth of knowledge and experience!
Old Sep 28, 2002 | 08:10 PM
wyskibumm's Avatar
Re: Power Door lock help? (little long)
Oh yeah, that was my problem too, i jsut email you, before i got a chance to read this post. my door locks stopped popping up. so i bought one of these:
http://cgi.ebay.com/ws/eBayISAPI.dll...tem=1384406700
it was a pain to put it, i nearly gave up and tossed the car in the lake, but i got it in. now it works excellent.
lowpost99
Oct 26, 2025 06:53 PM
mvm062
Nov 30, 2020 09:00 AM
trungg86
Sep 4, 2015 04:58 AM
Hailstatejig
Sep 2, 2015 06:52 AM
