speed cut off?
speed cut off?
I was woundering, I own a 92 SE 5spd and I was racing again my friends Navigator(rental) And when I got to 210 it seem to stop accelerating as if there was a speed cut off. Could it be because itès a canadian model?
Re: speed cut off?
The VG will get up there too, it just takes a little longer because the VG topend isn't that strong (not VG bashing, I used to have a 89GXE I loved, but it died in the topend)
Thanks anyways. I don't usually drive at that speed and to many cops around to race anyway but I was just wondering cause as you said I read on posts that people went over 140 mph but ??????
km/h
he was going about 130 mph.
Re: Re: speed cut off?
Originally posted by «§»Craig B«§»
I know on the US models, there is no speed governor, several guys with 92-94SEs (the VE engine) have gone well over 140 with no problem. I'm not advising it, but the car is strong enough to get there.
I have a 90 SE and I have experienced the situation where the car seems to falter and then slow when i hit about 125+. But are you saying there is no speed governor on the 90 SE or do you know? Thanks
Originally posted by Matt93SE
NO us or canada-spec Maxima is governed. If you couldn't get over 128mph, then there is/was a problem with your car.
Could it possible be the rev limiter at 5500rpm that you hit that causes the car to seem to die. I think that is what mine was on my 94 GXE. I was coming back from Birmingham AL and me and this VW Jetta were just getting our roll on...he would lead for a bit then I would lead (not racing) but at about 115-120mph my car started to act like it was sputering out so I slowed and it had regained power. When I got back to that speed it did it again. I noticed when you send your computer in for a revamp they (JWT) they raise the rev limiter. This may be our problem and not a top speed limiter.
Good Luck
Good Luck
Originally posted by grody
no kidding. the only think keeping me under 130 in my bone stock gxe is the suspension. (I don't like that floaty feeling
fastest i ever made it up to was 130...how do you know you made it up to 210?? VE speedos only go up to 145
mine vibrates at any speed above 65ish
geez i didnt know stock springs can be THIS bad
Originally posted by male
Yeah, my SE's 140K mile suspension likes to float alot above 120..makes for sweaty palms and white knuckles!
Good Luck
Good Luck
I've had my GXE clocked by a cop at 143 before with only an intake (and tons of suspension and brakes), so I know there's no governor on it.
probably what you're running into is the tranny trying to kick into OD from 3rd gear. at those speeds, it's a looong shift. takes almost two seconds.
knight_yyz
Nov 1, 2015 01:34 PM
magiconthetire
Oct 26, 2015 09:03 PM
RealityCheck
Oct 2, 2015 06:34 PM
