Front Passenger door window malfunction
Old Sep 30, 2002 | 06:07 PM
GDavisCT's Avatar
One fine day, the front passenger door window slipped down into the door all by itself. The electric window lift controls had no effect, except for a clicking noise at the up position.
After disassembling the inner door panel and examining the mechansim, the cable on the the upper track pulley has jumped off, the nylon upper track pulley has a chunk missing on the side ridge where the cable jumped out.
The regulator which rides up and down the fixed track and carries the window is intact, with the epoxy glue joints that hold the window glass to the regulator still holding perfectly.
The lift cable joint to the regulator has come loose.
How do you reconnect the lift cable to the regulator? How do you replace the upper nylon pulley? Will the window glass have to be shattered to get the regulator & track out of the door to order to make the cable clamp repair?
Old Sep 30, 2002 | 06:11 PM
«§»Craig B«§»'s Avatar
http://forums.maxima.org/showthread.php?threadid=155304
if you look at this post, towards the bottom of your question, there is a "edit/delete message" link
from there, you can delete this thread
carguy96
20
Feb 6, 2021 06:21 AM
vingodine
45
May 21, 2016 12:46 PM
max1029
Aug 26, 2015 09:51 AM
spidgeon
Aug 24, 2015 11:14 AM
follyburr
Aug 7, 2015 09:50 PM
