How to remove ABS Sensor
Old Oct 11, 2002 | 10:54 AM
maximalover's Avatar
Hi Guys,
I am planning to replace a front wheel bearing. I need to take the hub,bearing and knuckle to the machine shop.
To do this ABS sensor is coming in my way. I am having a hard time removing ABS sensor...
Can some one help me please...
Any tricks in removing the ABS (front left)..
I tried removing three small bolts around the sensor.. But the sensor didn't budge a bit.. There I see a plate attached to sensor.. it is heavily rusted...!!!
This is my third post on the same issue.. I am sure some of you would have done this.. Please
Old Oct 11, 2002 | 12:18 PM
mtcookson's Avatar
there is a little screw kind of behind the sensor that is really hard to get to that holds it on. you might check to see if you got that one. if you did i have no clue what else it could be, sorry.
Old Oct 12, 2002 | 08:58 PM
jwtarbaj's Avatar
Re: How to remove ABS Sensor
according to my Chiltons it is like the rear sensors and very troublesome to remove. It fits inside a "bracket" and it is very snug. I had to push it out with a screwdriver and hammer. Afterwards it was difficult replacing the new one in the bracket. It is mostly only a magnet and converts to electric pulses. Hope this helps.
mvm062
Nov 30, 2020 09:00 AM
bbsitum
Sep 6, 2019 07:31 PM
Djsmaxima
Sep 14, 2015 11:58 PM
maximusrising
Sep 2, 2015 09:55 AM
