Interior Ground points on 3rd Gen
Old Oct 16, 2002 | 04:35 PM
drstillpatient's Avatar
Does anybody know where the interior ground points are located? i saw one below the steering column above the brake pedal on the firewall...does anybody know where the others are located?
thanks in advance.
Old Oct 16, 2002 | 04:55 PM
eric93SE's Avatar
Re: Interior Ground points on 3rd Gen
thanks in advance.
There is another on the left kick panel on the drivers side, you'll also find two ignition relays there as well.
What i did was, removed the bolt for the ground, then used a fine file to remove the paint off the body, cleaned the contact surface of the bolt with a wire brush, also cleaned the copper connector with the wire brush, Then after reinstalling I used some dielectric grease all over the bolt and bare metal to prevent any oxidation.
Old Oct 16, 2002 | 06:29 PM
thanks eric!! anybody know of anymore?
Old Oct 16, 2002 | 08:59 PM
90Maxima's Avatar
Yeah, if you take apart the center column where the stereo is, after removing all the plastic, theres a screw with a big fat ground wire just like the one in the kick panel. you can see the metal column that it attaches too, its resting on my gas pedal in my sig pic, if you can find it )
Old Oct 16, 2002 | 09:23 PM
lol 90max...what happened to your dash?
do u mean i will have to take apart the whole dash to get to it? or just the center trim?
thanks
Old Oct 16, 2002 | 10:12 PM
90Maxima's Avatar
Nah, just remove the center trim, once you get all the plastic off, you'll see two metal bars that support the center, on the left one is where its connected, i just removed the whole bar in this pic.
stevesmax
Dec 17, 2020 11:57 AM
Matt93SE
May 24, 2019 02:58 PM
rbaker100
Aug 28, 2015 08:11 PM
ViciousVQ30
Aug 5, 2015 05:40 PM
