disconnect vtc during boost?
Old Oct 16, 2002 | 12:04 AM
4signs's Avatar
supose you had a 93se, and where boosting 5-6psi (intercooled dim 18x7x3) would it be a good idea to grn the vtc?
Old Oct 16, 2002 | 12:16 AM
pezking4's Avatar
This is your first post? What exactly about the vtc's makes you want to know if you should disengage?
Old Oct 16, 2002 | 12:54 AM
4signs's Avatar
I guess what i am trying to say/ask:
grounding the vtc (so that the timing doesnt advance when you build rpm and boost pressure)to avoid detonation.
would this be a good idea? or would just retarding the the timing and leaving the vtc alone be a better choice?
Old Oct 16, 2002 | 01:34 AM
pezking4's Avatar
Seems like you could just leave the vtc and timing alone, of course I don't have experience boosting. Be advised, with a first post about boosting a VE things could get interesting
Old Oct 16, 2002 | 10:05 AM
DA-MAX's Avatar
Eat, sleep, and sh*t 2JZ
I dont think the VTC has to do with ignition timing, its involved with the cam timing I think. Ignition timing is what you are thinking of, and yes on the VE 10:1 I would think maybe a few degress retard would be optimal.
Old Oct 16, 2002 | 10:35 AM
male's Avatar
I agree, I'm pretty sure the VTC is Valve timing, not ignition. However, you need to find out how the relationship between the intake nad exhaust valve is altered when the VTC engages (ie overlap) Turbo engines don't like alot of overlap. In NA engines, overlap helps with the scavenging effect, the momentum of the column of exhaust gas leaving draws the fresh charge in when both valves are open at the same time (overlapping). On turbos, the cooncern with scavenging is essential gone. I'm sure it still occurs to some degree, but now you have a major pressure differential between the intake charge and the exhaust gases exiting the chamber. The pressureized intake charge needs little help getting in there, it is being rammed in by the compressor. Having the exhaust valve open too long will cause fresh charge to be blasted out the exhaust port. poor performance results with respect to power procuction, gas milage, emissions, etc. That's why turbo cams are typically lower lift (more than say, our stock NA cams, but less than an aggressive aftermarket NA cam) with less overlap.. If the VTC increases overlap (not sure if it does, but I'm sure it changes lobe seperation) at higher RPM, then diabling it might be a good idea. But the only way to know for sure how it will effect performance is to do it, dyno it, and dyno it ungrounded. Sound reasonable?
Old Oct 16, 2002 | 03:16 PM
4signs's Avatar
thanks male, I dont know why I was thinking vtc had anything to do with timing ( I replaced mine last summer)
Old Oct 16, 2002 | 03:42 PM
4signs's Avatar
just wanted to let everyone know that I have been using this board for almost three yrs ( I use search alot )I use the name prettyboymax (couldnt remember my old email, pass word just made up new name) I was working on turbocharging my ve around the same time czar was boosting his. To make the story short, I am in the military, and when the tragdy of sept 11 took place, I had to post pone the project. Well Ive been back from my mission and picked up the project from where I left off. so this really isnt my fisrt post, but back then I never posted much anyway
Old Oct 16, 2002 | 04:07 PM
James12345's Avatar
Sweet...how far along are you on the project?
Old Oct 16, 2002 | 05:51 PM
pezking4's Avatar
That's good to hear. It was late at night and I saw a newbie turbo post and was wondering
Old Oct 16, 2002 | 09:33 PM
4signs's Avatar
What really holding me back is an input shaft bearing for my tranny. I already replace the flywheel with the aasco and the clutch with act. As for the turbosytem;im waiting for my exhaust piping to come in, and I have to finish welding the intercooler pipes.
Old Oct 16, 2002 | 09:48 PM
James12345's Avatar
Hmmph check your e-mail
Old Oct 17, 2002 | 05:15 AM
male's Avatar
Yeah, those input bearings SUCK. So you got the clutch and f'wheel in and have that noisy bearing, right. Same crap happened to me..thought it was the release bearing, so I put a clutch in it only to find it was that damned input bearing.
litch
123
Jan 4, 2024 07:01 PM
aw11power
Oct 10, 2021 04:57 AM
gigabyte
Jan 6, 2017 06:05 PM
doctorpullit
Mar 29, 2016 11:08 AM
maxima297
Sep 30, 2015 03:32 PM
