car idles at 1000 rpm.....02 sensor bad?? please help!!
Old Dec 23, 2000 | 04:45 PM
1FasMax
My 92 SE mostly idles at 1000 rpm.....and when I strat it when cold....idles at 1200...and drops to 1000 in about 10 to 15 seconds....when it used to idle at 1500 when cold for a couple min and slowly drop to 750 idle...is this a bad 02 sensor????
Old Dec 23, 2000 | 07:04 PM
Sarah99GXE's Avatar
Maxima Princess
Hmm My car ususally idles @ 1000 rpm if I'm in Park, in drive it idles @ 700-800 rpm...what gear are you in, and when I start my car it idles @ 1500 rpm and drops to 1000 in about 4-5 minutes..
Old Dec 23, 2000 | 07:29 PM
Foo90SE
An intake vaccume leak is what id check for first..that can make it idle high..check for a hissing sound from any vac hoses under the hood.
Old Dec 24, 2000 | 08:35 AM
fornimage's Avatar
idle...
Yeah, check the vacuum lines for leaks or disconnections. Typically though when there is a vacuum leak the rpm's tend to "hunt", meaning the rpm's will fluctuate from high to low. When was the last time you worked on your car? Possible u accidentally disconnected a vacuum line like I have (off the intake manifold). Possible tune up time! Check all the simple things before going with the last resort of adjusting the A.A.C Valve (idle speed. Good Luck!
Lakersallday24
Jun 16, 2019 01:35 AM
kjlouis
Nov 24, 2018 06:09 AM
maxinout93
Oct 27, 2015 01:29 PM
doobadoo
Aug 15, 2015 06:43 PM
Maxboy23
Aug 11, 2015 11:59 AM
