Need electrical help bad!
Old Dec 24, 2000 | 10:11 AM
Foo90SE
Ok last night my seat belts went foward when i opend the doors and now wont go back. I found out also this morning that none of my power windows are working either! I dont know how the 2 are related but does anyone know where any fuseable links are or relays that control either of these? this really sucks
Old Dec 24, 2000 | 10:15 AM
«§»Craig B«§»'s Avatar
should be the bottom fuse (10A) on the left hand side of the fuse panel (lower left side of dash)
it controls seat belts, windows, etc
this should be the problem and just replace the fuse and it should be fine
<img src="http://www.geocities.com/bracecraig/maxima/fuses.gif">
Old Dec 24, 2000 | 10:22 AM
Foo90SE
Uh oh...damn..thanx for the info on the fuse..it was blown..and it blew the one i put in it as soon as i cut the switch on..looks like i have a short Off to go trace it down..*ugh*
Old Dec 24, 2000 | 10:54 AM
Foo90SE
I found the problem
i re-mounted my amps last night to the back of the back seat and..well..found out that i put a screw all the way thru the harness that runs across the top of the back seat(that i didnt know was there). Its all good now
Old Dec 24, 2000 | 11:06 AM
89GXE
Yuck
Yep seen that before a guy once mounted amps in his
240 and drilled into the gas tank. Just be carefull when
mounting stuff in your car.
Old Dec 24, 2000 | 11:40 AM
Originally posted by Foo90SE
I found the problem
sweet, be thankful it was something that simple =)
Unclejunebug
Apr 2, 2016 05:42 AM
RealityCheck
Oct 2, 2015 06:34 PM
leatherneck
Sep 30, 2015 09:16 PM
HerpDerp1919
Sep 29, 2015 02:02 PM
