vg knock sensor help?
Old Oct 17, 2002 | 09:52 PM
darrick's Avatar
Dallas Nissan Enthusiast
any one know of any wrightups on knock sensor replacement on the VG? seems like my timing is retarding more as the car gets warmer.
Old Oct 18, 2002 | 07:04 AM
male's Avatar
Don't think the VG has one. Usually on higher compression engines.
Old Oct 18, 2002 | 07:20 AM
darrick's Avatar
is this ture?
man what can it be?
Old Oct 18, 2002 | 07:26 AM
male's Avatar
Re: is this ture?
Originally posted by darrick
man what can it be?
Well, I need more info, then i can give you my ideas. Feels like it's retarding the timing? That will not happen in our cars to my knowlege. What's happening and at what RPM? Losing top end I assume.
Old Oct 18, 2002 | 09:36 AM
darrick's Avatar
yeah
well when ill frist get in it runs fine as i drive it longer the more to rpms drop .So at frist it will not pull above 4k then as it gets warmer 3k then after a hour or so it wont rev above 2k,but it will rev just fine in park.
Old Oct 18, 2002 | 09:39 AM
MaxHeadroom's Avatar
Yea the VG has one
But your lucky cause its below the exhaust manifold on the rear of the engine. You can jack the car up and get to it. Mine on the other hand is buried undrnrath the intake manifold meaning a 7-10 hour job. Those damm japs!
Old Oct 18, 2002 | 10:26 AM
darrick's Avatar
so i will see it if i jack the car up?
thanks for any help guys
Old Oct 21, 2002 | 02:11 PM
darrick's Avatar
dont anyone think this could be my fuel pump?
I hope its not,the darn things are $300.00
Old Oct 21, 2002 | 02:54 PM
Mizeree_X's Avatar
Getting back to his roots
Re: dont anyone think this could be my fuel pump?
Shouldn't be the fuel pump. If the fuel pump is dying then you should have idle trouble from the get-go, and the car becomes increasingly more difficult to start (at least that's what I saw). And, for some reason, although an OEM fuel pump is $300, a Walbro high output one is only $100. Go figure! I managed to find an OEM for $120, but the brand sketched me out, so if it fails again, I think I'll know why.
Old Oct 22, 2002 | 07:31 PM
darrick's Avatar
I wounder
if it could be a injector? what happens when the injector gos out?
Old Oct 22, 2002 | 09:36 PM
mtcookson's Avatar
i think if it's an injector it would be like a misfire. have you checked you ecu for codes?
Old Oct 23, 2002 | 03:44 PM
darrick's Avatar
no not really sure how to do that
I gess I need to search for that huh?
Old Oct 23, 2002 | 06:14 PM
jwhite's Avatar
Re: no not really sure how to do that
Maybe it's the catalytic converter. If that's shot then it'll run worse when it gets hot.
Old Oct 23, 2002 | 10:11 PM
darrick's Avatar
thats a good idea ill check that out
hum what else to check?
Old Oct 24, 2002 | 12:23 AM
MaximaGXE93's Avatar
Re: Yea the VG has one
Originally posted by MaxHeadroom
Those damm japs!
I feel offended, yet...not.
Old Oct 24, 2002 | 04:59 AM
male's Avatar
Re: Re: Yea the VG has one
I was waiting for someone to bring that up...let's keep it PC people
Old Oct 24, 2002 | 12:03 PM
Re: Re: Re: Yea the VG has one
Ay Male, what does "PC" stand for?
my03maxima
Jul 28, 2024 07:40 AM
Kyle Lee Cleveland
Sep 28, 2015 09:01 PM
DC_Juggernaut
Sep 28, 2015 04:07 PM
