how to remove windshield trim
since water is still dripping right at the passenger side carpet from somewhere under the grove box every time after car wash or heavy rain. i am going to check the drain tube for the sunroof and also the windshield trim. does anyone know how to remove the trim to check the drain tube at the A-pillar? Also, how to remove the windshield trim to check for sealant crack?
mine is a 93' max sohc automatic
Re: how to remove windshield trim
check the door trim seals.. they're the most common to fail, as you open and close them every day.. way more often than any other part on the car...
(think of how many zillion times your driver's door has been opened and closed over the years. it's amazing they still stay on the car.)
Re: Re: how to remove windshield trim
Where is the Cowl vent? I have seen this term a couple times, but i still don't have an idea of where it is and how to access it..
Originally posted by shavedmax
a pilar inside is clips, just pull off. the windshiled is a urethane seal, therfore you have to cut it out and have it re sealed. i would check your cowl vent first. take out the vent, fill the cavity with water, if its filling you have a drain problem there, flush out the sides and ure good.
Re: Re: Re: how to remove windshield trim
REDinLV
Aug 15, 2024 12:30 AM
jmlee44
Oct 2, 2022 02:13 PM
RealityCheck
Oct 2, 2015 06:34 PM
JakeOfAllTrades
Sep 30, 2015 03:16 PM
