Reducing Interior Noise
Old Dec 26, 2000 | 04:23 PM
maximusSE's Avatar
*HELP* How Do I Reduce Wind Noise
ok, i have a 1991 SE 5speed, with 154,000miles on it...it get rather loud inside at about 60 and increases when going faster(not that i ever go fast..hehehehe), but i was wondering if there is a way to reduce the noise without too much expense and what do i need?...thanks
oh i forgot...i have a friend with a 1991 GXE and his is significantly more quiet inside...its not the engine thats loud, it is the wind noise
[Edited by maximusSE on 12-26-2000 at 07:58 PM]
Old Dec 27, 2000 | 05:17 AM
brubenstein's Avatar
You may need to either replace the weather stripping, or adjust the door latch strikes (on the body) so the door closes tighter.
Old Dec 27, 2000 | 07:47 AM
Foo90SE
my car has loud noise at high speeds that sounds like wind noise, but i think its road noise from the tires. sounds about the same as wind noise but when i go over a bridge it changes tone. iv been trying to figure out why for months now hehe...
Old Dec 27, 2000 | 08:56 AM
maximusSE's Avatar
Ok so where do i buy the weather stripping is it just regular kind or is there some special kind for the car?
Old Dec 27, 2000 | 09:37 AM
Matt93SE's Avatar
STFU n00b!
you can get the weather stripping at your locel dealer.. I wouldn't recommend buying aftermarket stuff there..
also make sure the door frame isn't bent.. try to figure out where the air/wind noise is coming from.. stick a strip of paper about 2" wide in the door frame, then slam the door on it.. try to pull it out.. if it's tight, then you don't have any air leaks. if it slides out, then the wind noise could be coming from that area.. try it across several places on the top part of your door (around the window frame area)..
also check and make sure there's not a pebble or something in the window trim that is keeping your window from rolling up completely.. I've found that to be a problem quite often too.
Old Dec 27, 2000 | 03:46 PM
zobsky
I seem to have the same problem with noise on a 92 SE and as prevoiusly noted, it seems to be more (though not entirely) a matter of road than wind noise, especially at speeds in excess of 60 mph). I concur too with the observation that the 3G GXEs are quiter inside than the SEs.
Could it have anything to do with suspension or tyre type?
Has anyone with an SE overcome or reduced significantly the
92SE / 5 speed and nothing else (for now)
Old Dec 27, 2000 | 04:37 PM
maximusSE's Avatar
Ok I did what Matt93GXE said about checking the door seal...the driver side door must not be sealed well, i also noticed while diving today, that the sunroof makes quite a bit of noise too(i dont have the cover anymore for it, but that shouldnt matter...right?). So then i checked the driver door...looking at the weather stripings, how does it come off? it looks like it will have to be cut off, but what if it makes it worse.. Any ideas?
I dont know why the GXE are quiter, maybe the suspension...but i am new here so i dont know much.
Old Dec 27, 2000 | 05:21 PM
The sun roof inside cover does make a noise difference.
The first, outer seal, goes along the "A" pillar and continues along the top of the body around and down the "C" pillar. I don't think it's glued on at all. Just start peeling it off by the base of the windshield. This is the main seal for keeping out wind noise.
If SE's are noiser, it's transmitted tire/road noise.
Old Dec 29, 2000 | 02:06 PM
JeffesonM's Avatar
living out of a maxima...
Sorry about the old post, but I've been having the same damn issues. I just put in Dynamat in all four of my doors in hopes of better stereo performance. The biggest difference I noticed was in interior noise: much quieter at all speeds. Anyone else have any experience with Dynamat? I was thinking of putting this stuff on the bottom of the car also (under carpet). Think this would help? or just be a big waste of time and money?
Old Dec 30, 2000 | 05:39 PM
ray89se's Avatar
dynomat is woth it
i use it all the time it does make the car heavier and no more rattles when hitting a bass note
Old Dec 30, 2000 | 06:21 PM
FAST4EN's Avatar
DynoMat is worth it!!!
I used a "rubberized" spray in a can on the plastic pieces in the fenderwells and it's helped a little.
My Dynomat theory: The more the better...but too much will slow you down (weight)....
Old Dec 30, 2000 | 06:30 PM
Brandon90gxe's Avatar
its wierd, i get wind noise only on the passenger side, i checked the stripping and its fine, but the noise seems to mainly be coming from the mirror... any suggestions?
Old Dec 30, 2000 | 08:30 PM
91MaximaGxR's Avatar
91 GXE
My GXE also has wind noise at about 70mph (or i would expect it does cuz i never wen that fast before hehe) i always thought that maybe the front windshield was replaced but i am not sure...i would say this is a common prob on all 3rd gen maxs
Jason
Old Dec 30, 2000 | 08:41 PM
speednsound007's Avatar
i dunno if I'd call it a problem...
more of a characteristic And it may make sense that the GXE's would be quieter since they are supposed to be the more "luxury" model.
PJ
Old Jan 3, 2001 | 11:22 PM
superdesi's Avatar
While parked overnight on my street, my drivers side mirror was hit by a stupid hit-and-run schmuck.
It did not break the mirror but I noticed a teeny chip near
where the mirror mounts to the frame.
Since then, at fast highway speeds, I hear a whine coming exactly from that area.
Check to see if you have any little chips or nicks around the mirror area or plastic mount.
user 11122324
42
Jul 18, 2022 03:35 PM
D Mason
Jun 21, 2016 04:43 AM
uttadms31
Sep 30, 2015 05:24 AM
