o2 Sensor replacement
Old Nov 5, 2002 | 07:58 PM
Spipedong90's Avatar
I just replaced my toasted o2 sensor. For a few months my gas mileage has been declining steadily, my idle worsening steadily, power lessening, and smoke has been coming out the tailpipe.
This weekend, it got bad. The car started trying to stall and it would flood and n ot start again for hours. So I finally bit the bullet and bought a sensor today.
So far, the idle's better, the power's back, the smoke's gone and I haven't had it flood yet. I'll make another statement about the gas mileage when I can calculate it.
In conclusion: If your car runs poorly and gets bad mileage...Check your oxygen sensor.
Old Nov 6, 2002 | 03:43 AM
Pervis Anathema's Avatar
Re: o2 Sensor replacement
You could also have the infamous broken manifold studs...
Old Nov 6, 2002 | 08:50 AM
maximalover's Avatar
I have two questions.. since you already replaced O2 sensor. I have difficulty in getting Bosch O2 sensor here
What brand was there (original OEM)in your Car before you did replacement? Bosch, NTK or some thing else
What brand did you get as replacement?
Old Nov 6, 2002 | 08:05 PM
Re: Re: o2 Sensor replacement
I have no Idea what brand was OEM. I do know it was all plugged up and nasty looking. I chose Bosch over the OEM because I'm partial to their products and I feel they are of excellent quality.
Old Nov 6, 2002 | 08:07 PM
Yeah I think I have that also. I have exhaust fumes coming up out of my hood. If I listen I can hear the exhaust coming out of the manifolds. Both front and rear (Left and Right?) Manifolds have the problem. Sigh, more space in the pit for money to fall into.
Old Nov 6, 2002 | 10:21 PM
Jeff92se's Avatar
I'm needing a caw
I just replaced mine today. The OEM sensor didn't have any markings except for a Nissan hamburger logo on the sensor. I bought the NTK and it's a direct replacement. Connector and wiring harness clamps are all exactly the same. You have to steal the black clip off the old sensor so the connector will attach back onto the motor mount but that's it.
I had 140k on my old one and you could tell it was time. I was only getting about 290ish miles to every 15 gal of gas. Plus it would idle slightly rough despite a recent tune-up.
I could tell it ran noticably better on the way home.
Old Jun 2, 2010 | 09:30 AM
maxinout93's Avatar
where is the oxygen sensor and how do I get it off?
Old Jun 2, 2010 | 09:39 AM
BenStoked's Avatar
Jesus was a Zombie.
you can see the bung on this one, just to the right of the flex section.
your best bet is to spray it down with penetrating lube, wait, and hit it with an o2 sensor wrench.
if you don't have one, you can try using the CLOSED side of a box wrench, to avoid stripping the head. will have to disconnect the harness and fish it through, or cut the wires, depending.
I think the o2 sensor wrench is one of the loaner tools autozone/oreily has, but not sure.
Old Jun 2, 2010 | 10:22 AM
Jeff92se's Avatar
I'm needing a caw
O2 sensor socket. Harbor Freight. Why not?
Old Jun 2, 2010 | 12:37 PM
Cliff Clavin's Avatar
Way out West
How old is this thread?
I haven't heard from Keelan in years.
Old Jun 2, 2010 | 01:49 PM
Hatmanafro's Avatar
ZOMG.. this is like the oldest thread ive seen.. haha. cobwebs and ****..
Old Jun 2, 2010 | 01:55 PM
maxinout93's Avatar
I got 2 from the local pull-a-part I just used an adjustable wrench and it came right off. The hard part was trying to unplug the darn thing from the electrical connector, I just cut it off at the end of the electrical connector.
Old Jun 2, 2010 | 02:17 PM
Jeff92se's Avatar
I'm needing a caw
Used 02s. I can't recommend that.
Old Jun 2, 2010 | 04:43 PM
maxinout93's Avatar
sometimes I like to swap out things to see if it makes a difference. Theres gotta b a better way to be able to unplug those things!
Old Jun 2, 2010 | 05:44 PM
maxitech's Avatar
Wow, this one is even before my time...
Old Jun 2, 2010 | 09:13 PM
maxinout93's Avatar
lol well i did search the threads stead of making a new one lol
Old Jun 2, 2010 | 09:15 PM
maxinout93's Avatar
come to find out when I went to replace the sensor on my car, the darn thing was so loose, I could unscrew it by hand. I just screwd it back in tight. Seem to make a little bit of difference in driving.
Old Jun 5, 2011 | 01:09 PM
dhughes214's Avatar
Ok, I'm gonna try and revive a dead thread here, since I haven't met my 15 post quota to start a new one. I am trying to check my o2 sensor, I heard a good way to see if it's faulty is to unplug it, and see if that helps with performance. I am trying to follow the wires up to the plug, but I lose them. Does anybody know exactly where the plug is?
mrc00l88
Jan 25, 2024 01:14 PM
Maxboy23
Aug 21, 2015 11:02 AM
maxinout93
Aug 20, 2015 02:17 AM
doobadoo
Aug 15, 2015 06:43 PM
