Replacing rear exhaust manifold studs....How hard??
Old Nov 19, 2002 | 07:12 AM
nstymax93's Avatar
My rear exhaust manifold studs need replacing. I was wondering how hard would it be to replace those and what if they need to be drilled out what would have to happen. I am getting a y-pipe and if i replace that then i want to replace the studs too instead of paying $300 for the shop to do it. Thanks
-Mike
Old Nov 19, 2002 | 07:35 AM
nubiannupe's Avatar
OG Maxima.org Member
The only thing I can offer in regards to that, is that it seems to be easier to win the lottery than to replace those fargin' rear studs!
Old Nov 19, 2002 | 07:37 AM
RosenKen's Avatar
Yeah, it's tough. Best chance is to get the car on a lift, have a hoist attached to the engine to hold it up, sicne you will have to removet he rear engine mount and hardware. It'd be even easier if you remove the entire engine crossmember underneath. Then you must removet he y-pipe and rear exhaust manifold, and you should have some room to work with down there. Best to let a shop do it, if they screw it up, let them fix it!
Old Nov 19, 2002 | 07:43 AM
nstymax93's Avatar
yeah thats what i will probably do. Just let the shop take care of it.
thanks anyways guys.
-Mike
Old Nov 19, 2002 | 01:47 PM
Nismomaxt's Avatar
-Mike
Ive already said this in another thread but Im Pulling the read head this weekend because of a broke stud. From all the research Ive done that seems to be the way to go. Ill have the results (HOPEFULY) monday and with pics.
Dano
Old Nov 19, 2002 | 02:52 PM
RosenKen's Avatar
Dano
Do you have new head bolts? Don't reuse the old ones. They stretch when you torque them down. You must get new ones.
Old Nov 19, 2002 | 03:47 PM
Nismomaxt's Avatar
Have bolts and head bold tool too. Have tons of gaskets and nuts and bolts and washers. Hope I can figure out where they all go.
Old Nov 19, 2002 | 04:19 PM
RosenKen's Avatar
Cool good job, looks like you've done your research. Do you have a VG or VE? I yanked both my VE heads for exhaust stud fix, VTC replacement and oil galley cleaning (they weren't dirty at all). IF you have a VE, replace your knock sensor and subharness while you're down there! And your water pump will be much easier to replace then. Food for thought...
Old Nov 19, 2002 | 06:17 PM
nstymax93's Avatar
Thanks agian. I look forward to reading your write up when you complete this task.
-Mike
Old Nov 19, 2002 | 06:24 PM
RosenKen's Avatar
-Mike
I don't think the average shade-tree mechanic is going to remove their cylinder heads just to drill out exhaust studs. It's a very time consuming and laborious procedure and you had better be sure everything lines back up when it's all back together.
Go to www.4dsc.com/articles for other write-ups on stuff
vingodine
45
May 21, 2016 12:46 PM
Huttig2009
Sep 25, 2015 03:31 PM
MAXSE5SPD
Aug 23, 2015 12:06 PM
MaximaDrvr
Aug 19, 2015 08:20 PM
george__
Aug 18, 2015 07:06 PM
