anyone know
Old Nov 19, 2002 | 08:04 PM
lilcc
anyone know
does anyone know where the power door lock brain is? My power door locks quit working along with the rear windows. I looked for a short but nothing else seemed to be wrong.
Old Nov 19, 2002 | 08:29 PM
MaXiMaSe21's Avatar
Re: anyone know
it's in a box located under your steering column, i looked on craig b's website re soldered my connections and my spazzing windows and locks work a lot better than before hope this helps.
Old Nov 19, 2002 | 08:35 PM
Nismomaxt's Avatar
Re: anyone know
Theres a door lock timer located inside your center console, above the ecu. I realy doubt that would be the problem but thats all I can find for a lock "brain"
Old Nov 19, 2002 | 09:08 PM
«§»Craig B«§»'s Avatar
no, you have a 90 so you do not have a door lock timer like the others were describing. That is only in 92-94 models and it's located just to the right of the steering column and it's a grey plastic box like MaximaSE21 mentioned. It's not really above the ECU or in the center console.
http://www.exclusiveatlanta.com/maxi...ck%20Timer.jpg
this is pj93max's 93GXE and that grey box with the 2 harnesses unplugged underneath it is the door lock timer
Old Nov 19, 2002 | 09:09 PM
Cutler's Avatar
make sure all connectors are tight
Old Nov 19, 2002 | 09:57 PM
if you could just stop whoring this forum, that'd be greeeeat
thanks
Old Nov 19, 2002 | 10:49 PM
Jon91SE's Avatar
Pusssseeeehhhh
Old Nov 19, 2002 | 11:04 PM
Cutler's Avatar
thanks
I met you at Nopi, i am done by the way
Old Nov 20, 2002 | 04:47 AM
yup, I remember you
I just saw Office Space on tv the other day so I felt the need to respond to your sig
