Yo, wassup so i'm wonderin'.......
Old Sep 9, 2000 | 01:02 PM
My car has 130k on it and at 60 or 65 it is fine, but when i push it up to 70-80, the steering wheel starts shaking unnormally, wonderin' if it is a bad ball joint or something. any ideas.
Old Sep 9, 2000 | 01:05 PM
RosenKen's Avatar
Same thing here...
I have 95K on my '93 SE, I had the tires balanced, no fix. I think I might have a slightly bent rim? What else could cause it? Maybe my brake rotor?
Old Sep 9, 2000 | 08:50 PM
Jeff92se's Avatar
I'm needing a caw
Both of you->
switch the front rims/tires to the back and see if it still vibrates. If not, you can eliminate the suspension. Bend rim, unbalanced wheel or old worn out tires.
Old Sep 10, 2000 | 02:28 PM
RosenKen's Avatar
I'll get to it soon
Been busy ordering and replacing parts on this car because it is new to me. Just put in new struts up front and I have new rear strut inserts sitting in the trunk. they are Gabreil VST's which so far handle really nice with the rest of the suspension stock. So when I replace the rear struts I'll swap rims and get an alignment. Also one of my rear lower control arms is bent so I'll replace that too, a new one was only $50 from http://www.nissanautoparts.com
Old Sep 10, 2000 | 09:03 PM
Chris91SE's Avatar
Eagles Fan 4 Lyfe
Re: Both of you->
yeah thats what i did for mine....it was an unbalanced wheel....it only shook from 65-75....from 75-120 it was fine
Chillboy
Jun 13, 2001 11:57 PM
gramenis
May 26, 2001 05:16 PM
JibaroMax
May 25, 2001 09:59 AM
