VTC engage disengage confusion cleared up.
Old Dec 16, 2002 | 10:28 AM
poorcollegeboy's Avatar
my VTCs have recently started to tick at start-ups ("oh crap"). could be due to the cold weather. after some thinking and reading the FSM i decided to wire a switch to ground/unground the VTC from behind the driver seat (grounded the VTCs right from the ECM not under the hood per Craig's directions). i'll ground the VTCs at start-ups, get the oil pressure up, then unground them when the engine is warm... no more ticking. i know this is not a new concept.... but i also wired an LED to the switch to see when the VTCs are engaging/grounded. when the VTCs are grounded the LED lights up. pretty cool findings. the "belief" on the org seems to be that the VTCs "engage" after ~3.2k rpm. i found that the VTCs are actually grounded when the engine is under load (like the FSM says) from any gear at any rpm. if you stomp on the gas the VTCs will be grounded (even 5th). after climbing up the tach and engine load is less, the VTC becomes ungrounded... makes sense. to test this i accelerated from a stop to see what the VTC's were doing. from a stop and launching hard the VTCs were grounded up until about 3.5k, shifted to 2nd close to redline and the VTCs were grounded again until about the same RPM. that is the extent of my testing this weekend.
Old Dec 16, 2002 | 10:44 AM
Jeff92se's Avatar
I'm needing a caw
VTC receive oil when at low rpms, keeping them in the retarded state. When conditions are right, they turn off(grounded?) and the intake cam advances 8 degrees or so.
I think this is a little different than my write up on the subject 2 years ago
Old Dec 16, 2002 | 12:51 PM
Maximajism94se's Avatar
that is awesome on the led thingy, howd u wire it up? i wanna do that...maybe i could put in where the extra space is on our dash? itd b like vtec stuff, but gayer cause ours malfunctions n crap...lol
keep us posted on what your findings r in the long run, like if it helps, etc
Old Dec 16, 2002 | 01:00 PM
5spd92SE's Avatar
Re: VTC engage disengage confusion cleared up.
Good job and info!
Now, who is going to be the first to come out with a "VTC Controller"?
Old Dec 16, 2002 | 01:28 PM
eric93SE's Avatar
At idle they are off (ungrounded, no oil). when your drive normal they are on (grounded, oil press is applied), up until 3.2K rpm (I thought the manuel said 4.2k rpm) where they turn off (ungrounded) and the engine gets its natural torque peak which is greatest.
Old Dec 16, 2002 | 01:32 PM
Jeff92se's Avatar
I'm needing a caw
Why would the cams be "off" at idle? "off" "on" "off" doesn't make sense to me.
Old Dec 16, 2002 | 01:58 PM
eric93SE's Avatar
Yup they are off, its in the FSM. I had intentions of scanning the pages but I've been a little busy (or lazy). When we 'ground' the VTCS it turns them on (completing the circuit) and engaging the sproket.
Thats why they clatter they are just floating there and the spring is'nt strong enough the fully disengage them. It may be a combination of the spring not being strong enough and sludge/varnish giving enough resistance/surface tesnion for the VTC to disengage.
Thats why I was giving advice to run a motor flush. But then finding that oil does not circulate when at idle, the oil flush will not clean the galley or VTC, UNLESS they are grounded during the flush!!
Old Dec 16, 2002 | 02:17 PM
have you gorunded them while running the flush, or has ne1 else? ive got about 1k until my next oil change, i just dont wanna b the 1st 2 do this...mine work and i wanna keep it that way
Old Dec 16, 2002 | 04:42 PM
eric93SE's Avatar
I'll be doing it soon
Miket2006
Mar 1, 2021 03:55 AM
D Mason
Jun 21, 2016 04:43 AM
AboveDaCloudz
Oct 8, 2015 11:25 PM
