For the guys who made a custom intake
Old Jan 1, 2001 | 08:16 PM
whitymax's Avatar
how did you mount your mass air and the filter so they do not bonce around in the engine bay? and pics or ideas? thanks
Patrick
Old Jan 2, 2001 | 07:15 AM
Chris Gregg's Avatar
Get Off My Lawn
I don't know what you mean by "jump around." Mine sits tight in the hole I cut running it behind the front bumper. The tube is stiff as well as the rubber connection hoses, so it stays put.
Old Jan 2, 2001 | 07:47 AM
Get Off My Lawn
I've got pics. They're at Photopoint, how do I get them here? http://albums.photopoint.com/j/albumlist?u=1428116
[Edited by chris gregg on 01-02-2001 at 09:57 AM]
Old Jan 2, 2001 | 09:50 AM
Matt93SE's Avatar
STFU n00b!
I used a strip of scrap metal and attached it to a bolt on the strut tower and a bolt on the filter adaptor. holds everything in place.
Old Jan 2, 2001 | 05:29 PM
Brandon90gxe's Avatar
sorr chris, but i think that spoiler makes your max look like a shopping cart. a dn whats that paintjob on the bottem of your max, and on your wheels....hmmm, interesting. no offense, just my opinion.
Old Jan 2, 2001 | 05:41 PM
Foo90SE
What material is that tubing made out of or where did ya get it? it looks similar to what iv got but tougher(which im looking for). Also, what did u do with the hose from the idle valve that goes into the stock airhose?
Old Jan 2, 2001 | 09:55 PM
MSK
Chris: How did you extended the MAS wires all the way to the front. Secondly, where did you buy that hose. It looks nice.
MSK 90SE
Old Jan 2, 2001 | 11:05 PM
HoJo's Avatar
Don't know where Chris is
But I asked him the same thing a while ago, the tubing is flexible exhaust, you can buy it from JC Whitney, to lengthen the MAF wire he cut the wires and soldered in wire to make it long enough.
I could be wrong on some stuff, Chris??
Old Jan 3, 2001 | 12:34 PM
Get Off My Lawn
Dabman, no offense taken. The paint was done professionally and the tires were done by me with a couple cans of spray paint. The oem wheels were loosing the coating and looked like crap so I painted the inner portion black and the outer ring the color of the car. The wing I like, and others do too, it's just preferance, you don't no biggie, I'll live. As far as the tubing, it is exhaust flex pipe for large trucks. I got the coated pipe but stainless steel is available too for double the cost per foot. The idle valve hose I ran into where the rear valve cover tube ran (into the side of the intake manifold) which is just opposite the front valve cover tube. I then just sealed off the line that runs to the rear valve cover, it's safe, there's even a mod in the "mod" heading on this forum to seal these off, that's what gave me the idea. As for the wires, just cut, buy new wire of different colors (5) and then sauder them. The sixth wire wraps around two wires specifically in a sperate bundle, this wire is bare and acts as a sheild. I took a 10 gauge wire, stripped it and seperated it into two strands, then wrapped it around my new wire and suadered it, then used wire tape to insulate and protect. Done. Any other Q's?
rbuswell
Nov 12, 2016 04:11 PM
Ben2003GLE
31
Jul 17, 2016 08:13 AM
95Maxi
Aug 29, 2015 09:38 PM
maxipower
Aug 21, 2015 11:10 AM
MaximaDrvr
Aug 19, 2015 08:20 PM
