VG Heads on my 92 SE's VE?
Its my understanding that the only difference between the na VG and the VE is the cylinder heads. My VE needs new valve seals which will really suck. Im thinking perhaps i could fit some VG cylinder heads on it? Obviously, the bore of the two engines is the same. Anyone come up with any ideas as to why it wouldnt work?
Re: VG Heads on my 92 SE's VE?
Sarin
no no
Well I'm going to tell you, putting VG heads on a VE would be worst thing you can do to your car. The VE is a 24 valve, chain driven DOHC, where the VG is a 12 valve, belt driven SOHC. The fit is questionable The block is almost the same except there is probably some different in the mounting pattern. If you were even able to get VG heads on, your going to loose a bunch of power, as much as 30 horses. You can do one of a few things, 1, find new VE heads for your motor, hell you might be able to fit VQ heads, but you aren't gaining anything from that. 2, if you want to do a VG, there is no sense going back to VG30E, you probably want to have more horsepower. You will probably want to go with a VG30ET turbo which produces 200+ hp, or a NA VG30DE, which you can get out of a 300ZX or Infinity J30, that produces 222hp. You may scrape by with a VG30DETT, but its a very very tight and you will no doubt run into fit issues. Either way, don't do your car a disservice by putting a lower power engine in, or detuning it by putting on different heads, you'll regret it big time. Though I'm a big fan of the VG, I don't think it makes sense to take away from a car, especially power.
Sarin
Sarin
![Wink](https://maxima.org/forums/images/smilies/wink.gif)
replacing the valve seals is MUCH easier than anything of that sort. pull the heads and you can have someone rebuild them for you for about $300. that's cheaper than it would cost just to BUY the VG30DE heads, let alone figur eout how to install them and fit chain-drive sprockets on them.
Re: no no
I should have been more clear. I meant VG heads from the VG30DE. There would still be 24 valves man
S
Re: no no
Dood VG30DE heads use a timing belt and not a chain
. Even what would you do, rig a timing belt or rig the heads for a timing chain
![NoNo](https://maxima.org/forums/images/smilies/nono.gif)
![Crazy](https://maxima.org/forums/images/smilies/crazy.gif)
I should have been more clear. I meant VG heads from the VG30DE. There would still be 24 valves man )
![Stupid](https://maxima.org/forums/images/smilies/stupid.gif)
I forgot about the timing problem. I wonder how hard it would be to fit the VG heads with a chain setup? I guess i'll have to get the two heads side by side and see. As for the cost, dont assume im going to pay what you might have to for some VG heads. I know where a VG30DE is from a 92 Z32 than i can pull for fifty bucks. As for installing new valve seals being easier than this head idea of mine...no ****, but new seals wont bump it from 190 to 220 now will they. This VE has 430K miles on it, original manual trans. The rings are fine, but im sure i'll have to pull the engine for a rebuild before long. I can say this though, this forum/you guys are more helpfull than i imagined =)
Why not just install the entire engine LOL
? I'm hoping you have a FSM or take a good look at the VE in Jeff's old sig. It won't work!!!, good idea but not possible. It would be alot easier to just pull the motor, install pistons and get the headwork than to swap non-interchanges' from VG to VE. Here is something to consider assuming you get VGDE heads to work, the IM is different way different. It faces the wrong way and a VE IM won't fit.
![goofy](https://maxima.org/forums/images/smilies/goof.gif)
Originally posted by RosenKen
I think that's a record! You got a pic of that odo?
Originally posted by Sawby4president
Seriously. 430 grand puts some diesels to shame. I honestly would like to see a picture of the odometer, just for the novelty. Has it been rebuilt or overhauled ever? new gaskets even?
S
Originally posted by maximase86
Damn 430k, you must do a lot of highway driving, my 86 only has 187k on it. The only cars I know that have more than that is a Volvo P1800, and a Mercedes 240D Diesel. Both have past 1,000,000 miles. If you did a motor overhaul, I betcha you can reach that if you do a lot of driving.
S
S
I've heard of volkswagen diesels and honda gas engines (read somewhere on the internet about a guy with a 700,000 mile civic) making it to 700,000 and 800,000 miles, so it's doable. It's especially remarkable on a VE motor, with its redoubtable VTC system. Overhauling the motor would be cheating though, for me it's drive it until it dies.
knight_yyz
11-01-2015 01:34 PM
worldwiderecognized
09-30-2015 01:16 PM
