my ve turbo
Old Jan 13, 2003 | 05:28 PM
  #121
4signs's Avatar
I smell a challenge coming on
Ve-t vrs vg-t
can someone still get a hold of that guy.
Old Jan 13, 2003 | 07:42 PM
  #122
MAX420's Avatar
Ve-t vrs vg-t
Oh oh.... I like the idea of this one....... BTW 4signs..... Any plans on making a kit for the VE's ?
Old Jan 14, 2003 | 12:08 AM
  #123
4signs's Avatar
been thinking about it. I would like to do some more R&D before I would put one together. Im leaning towards just fabricating the pipes, unless there is a big demand for a kit.
Old Jan 14, 2003 | 09:07 AM
  #124
Maximamike's Avatar
Ve-t vrs vg-t
I know of a great spot and have access to a few DV cams for uploading online/editing. Hmm..
Old Jan 14, 2003 | 10:44 AM
  #125
nismo1989's Avatar
Originally posted by Sudesh
Umm..yeah thanks matt, but i already did that before asking for MORE pictures. I'm not majoring in computer science for nothing.
I have a few more pics of his car somewhere I think...
Old Jan 14, 2003 | 10:46 AM
  #126
dmontzsta's Avatar
Ford Only.
I put my money on the VE...mad top end power. You better not spin out of the hole though, or the VG will put a little on you
Old Jan 14, 2003 | 10:52 AM
  #127
nismo1989's Avatar
I think the VG may be able to have shorter coolant lines. It also seems to me like maybe the VG might be able to take more boost. It would have a better power-to-weight ratio, wouldn't it? The VE has that top end, though...
I have to admit I never thought anyone would actually turbo a VE. If this isn't the first, it's certainly the first I've heard of. So very, very impressive...
Old Jan 14, 2003 | 11:13 AM
  #128
male's Avatar
assuming both engines are in excellent running condition, totally stock internally, same turbo and boost levels, it would be a tight race. The VG would pull off the line harder, as they tend to make more torque, but the VE pulls at higher RPM. It would be close..short race to the VG, more than 3 gears go to the VE topping out. It would be interesting race to witness.
Old Jan 14, 2003 | 11:20 AM
  #129
DA-MAX's Avatar
Eat, sleep, and sh*t 2JZ
if the VE is a 5spd it will take the VG off the line....good ole VLSD will allow it to hook much easier. after the laucnh though its anyones game, there are many other factors to consider aside from the VE having "top end power"
  #130
dmontzsta's Avatar
Ford Only.
I see how you are basing your decision, but a stock VE 5 speed vs. stock VG 5 speed...the VE will pull off the line and continue to pull...so stock boost, levels,etc...should be the same outcome.
Old Jan 14, 2003 | 11:39 AM
  #131
DA-MAX's Avatar
what about piping lengths and bends(or the entire setup as a whole), pressure drop, fuel system effiecieny(one car might be running lean or rich)...just popping turbos on cars and saying this should be the outcome doesn't hold much weight IMO....there are other factors to consider.
Old Jan 14, 2003 | 11:41 AM
  #132
dmontzsta's Avatar
Ford Only.
oh god, here you come now I was making the same decision he did...
Old Jan 14, 2003 | 11:43 AM
  #133
Jeff92se's Avatar
I'm needing a caw
Even w/ the same psi, the two engines will react differently. I'd generally say, whatever race outcomes for na, will be just about the same for turbo.
But the VE is much better equipped to move the air than a VG. 4 valve heads, varible cam timing, "maybe" a better intake manifold design, direct on coil ignition etc..
But honestly, it's probably who ever designed their system better because right now, there is alot of ghetto systems and maybe 1-2 nice systems. But that's how it is for the 3-gens at this stage. In time we will see some better stuff.
Old Jan 14, 2003 | 11:46 AM
  #134
DA-MAX's Avatar
thats my whole point...but I didn't know how to put it as eloquently as you! IMO its gonna come down to design and efficiency not NA 1/4th mile times.
Old Jan 14, 2003 | 11:48 AM
  #135
Jeff92se's Avatar
I'm needing a caw
Mine went from ghetto to semi-ghetto .
  #136
dmontzsta's Avatar
Ford Only.
Hell yeah, tell him whats up Jeff. What do you have to say to that???
Old Jan 14, 2003 | 11:50 AM
  #137
DA-MAX's Avatar
no more aluminum foil rolls??
Old Jan 14, 2003 | 12:00 PM
  #138
male's Avatar
I agree totally..it's all about whose system is better designed and tuned. I have a friend who turbo'd an NA eclipse running 6 psi..that thing is a turd with turbo hiss. Once we get a few turbo 3rd gen's built, as it seems there will be several within the next year or so, we should settle this at the track. DA-Max is right..the intake piping from the turbo (and the IC installed) as well as the exhaust piping leading to the turbo will make significant changes in behavior. No doubt the modified Y will work fine, but a manifold that puts the turbo at the engine is definately a better design. Also, keep in mind that skipping the IC is better than routing all that piping to and from an improperly chosen IC.
Old Jan 14, 2003 | 04:44 PM
  #139
mtcookson's Avatar
i think the vg would do better. it's built for a turbo unlike the ve. but, only a test would show the truth.
Old Jan 14, 2003 | 04:55 PM
  #140
Jeff92se's Avatar
I'm needing a caw
In exactly what way is the maxima na VG engine "built" for turbo? Yes the VG Z31 turbo motors are purpose built but when talking about a maxima VG and VE, I think they are both equally capable. Both feature iron bocks and both haven't exhibited any abnormal HG failures.
Old Jan 14, 2003 | 04:58 PM
  #141
mtcookson's Avatar
most people are just getting the z31 engine or using it's block therefore making the engine they are using built for boost unlike the ve. i'm not saying the ve can't handle any boost i'm just saying the ve wasn't built with the intention of putting a turbo on.
Old Jan 16, 2003 | 01:28 AM
  #142
Dummy's Avatar
neither are built for the turbo, witht he exact same setup etc. theres no doubt in my mind the ve would pull away.
Old Jan 16, 2003 | 05:34 AM
  #143
nismo1989's Avatar
Originally posted by Dummy
neither are built for the turbo, witht he exact same setup etc. theres no doubt in my mind the ve wouldnt pull away.
Really? I would think the VE would have the advantage. More air moving in there... depending on the setup, of course. There's no doubt in my mind, however, which would be more reliable. The VE IMO is a lame duck anyway. Damn VTCs
Old Jan 16, 2003 | 05:41 AM
  #144
ObsidianIce69's Avatar
Who knows, don't those SR20DET sentras run the same tranny as us? Some guys put down big power reliably in those things. It's the big torque numbers that concern me. Our VG's are good at making torque, usually much higher than the HP level implies. Torque is what snaps your head back..and snaps axles and destroys trannies...I can't wait! mtcookson, where does your VGT stand?
They put doen relatively big number, , but the few that start to jump into the range of 350+ they start running into serious transmission issues, even the built trannies start coming up with serious problems, but like you said most of them stem from torque.
Old Jan 16, 2003 | 12:37 PM
  #145
mtcookson's Avatar
the z31 turbo engine (which seems to be commonly used when doing the swap) is built for a turbo, that's why there is one on it
Old Jan 16, 2003 | 03:03 PM
  #146
Maximamike's Avatar
A lame duck that'd rip the **** outta yours so therefore.. VG = ..?
Old Jan 16, 2003 | 04:13 PM
  #147
Dummy's Avatar
*DOH* what i meant to say was, there's no doubt in my mind the VE WOULD pull away.
Old Jan 16, 2003 | 06:03 PM
  #148
Nismo87SE's Avatar
The VE would definitly own the VG. Given basic intake, 3in exhaust, 10-12psi the VG would be around 205-215whp/250-270tq. The VE should be around 220-240whp with the same mods.
Old Jan 16, 2003 | 06:24 PM
  #149
mtcookson's Avatar
what about torque though? the ve really lacks low end torque whereas the vg has awesome low torque. add the turbo then you have isane top end. with the low end torque you could get the ve off the line then with the turbo you could pull away. the ve would probably just get all topend and not really gain any low end torque. we need dynos and some track times...
Old Jan 16, 2003 | 06:32 PM
  #150
Jeff92se's Avatar
I'm needing a caw
That might be "partially" true if you started from a roll @ 1,000 rpm. But when is the last time you did that?
Use a small turbo and the VE will start boosting as low as 2,300 rpm. Ask me how I know And w/ the ability to process the air w/ 4 valves and varible cam timing, guess what happens?
Ari, I agree on those numbers. W/ just 4-5psi, I estimated the power at about 240hp at the flwheel. Maybe 250hp. When I drove the 2k2 I30, it felt like my car on boost.
Old Jan 17, 2003 | 05:12 AM
  #151
MaDMaX024's Avatar
do you say that because you know what your car feels like on boost:evil:? or do you say that because you're hopeful thats what it'll feel like on boost ?
Old Jan 17, 2003 | 05:16 AM
  #152
nismo1989's Avatar
What? ... I guess so... whatever you say. The VE is a lame duck. That's why it had such a brief life, and now there's the VQ technology.
I'm not making a debate on which is faster. But there is no debate on which is more reliable. Besides, I haven't had a VE match me yet. Sure, there's plenty, but to say my car is slow or even slower because it's a VG is ignorant. In a battle of reliablility, though, the VG gets it hands-down. I do think that in most cases, however, a boosted VE would be faster. That is what I've been saying, so drop your defenses, pal, and enjoy your lame duck.
Old Jan 17, 2003 | 07:51 AM
  #153
dmontzsta's Avatar
Ford Only.
Lame duck? Ummmm...the VE was stopped in production cause it costs so much to produce, therefore the cheaper costing more refined VQ was made. How is the VG more reliable? I have 257k and still rip azz.
Old Jan 17, 2003 | 07:56 AM
  #154
nismo1989's Avatar
Ever had problems with your VTCs or crank angle sensor? If not, you're an anomoly. The VE seems to have all the problems of the VG, with the addition of a few extra extrememly expensive and time consuming repairs. Powerful, yes, but I hardly see the argument in comparing the reliability.
Old Jan 17, 2003 | 08:52 AM
  #155
Jeff92se's Avatar
I'm needing a caw
Crank angle sensor? Never heard of anyone having those problems. Remember VGs have injector harness problems and hose leakage problems at the injectors. VEs don't due to it's side feed fuel rail.
Old Jan 17, 2003 | 08:59 AM
  #156
nismo1989's Avatar
very true. I personally have been fortunate enough to never have had any injector problems, or even hose leakage. The only issues I've had with my engine have been cooling issues and blown head gaskets, but I'm pretty sure that was just from nitrous abuse.
I still stand firm in my belief that the VE would take the VG in a race, even a VE-T vs. VG-T, but I also stand by the belief that the VG-T would be a more reliable beast. Small descrepencies in set-up may make less of a difference than you think. After all, it is all about pushing air, right? There's no doubt that the VE has that advantage.
Old Jan 17, 2003 | 09:09 AM
  #157
DanNY's Avatar
Ad·min·is·tra·tor
hey you VE guys...where's your PCV valve? LOL
ok this thread is getting a little out of hand here.
there are fans of VG..
there are fans of VE..
pros and cons to both motors.
Old Jan 17, 2003 | 09:14 AM
  #158
CandiMan's Avatar
Say Candyman 5 times
Originally posted by DanNY hey you VE guys...where's your PCV valve? LOL ok this thread is getting a little out of hand here. there are fans of VG..there are fans of VE..pros and cons to both motors.
Ok, where's your oil filter. So who's going to have the honors of taking care of this thread?
Old Jan 17, 2003 | 09:15 AM
  #159
Lordrandall's Avatar
What do you think?
Old Jan 17, 2003 | 09:19 AM
  #160
MaDMaX024's Avatar
Originally posted by Lordrandall
What do you think?
gut feeling tells me hes boosted. logic tells me hes not(no threads claiming boost..actually, thats the first mention of jeff being boosted ive seen). which is right?
