Alarm Problem
Old Jan 4, 2003 | 11:53 AM
Dark Lord Bunny's Avatar
Alarm Problem
I have thise annoying problem with the factory alarm, and yes I have used the search function, but I can't find a thread that seems to pertain to my particular problem, maybe I overlooked something, who knows. My alarm seems to like going off at random and usually inopportune moments, with no apparent trigger. I have yet to find a fix, and am currently just leaving my car unlocked, which is a HUGE security issue but for now it beats running downstairs in the cold at 2 a.m. to disarm the damned thing. I was wondering if anyone has ever run into this, and knows how to fix it. I was thinkin the alarm box needs replacing, but im unsure to ehere it exactly is, under the steering column right??? Would anyone know the part number or the official part name in case it does need replacing??? I took it to my dealership and they said they needed like $150 just to open up all the old manuals and stuff and trace the wiring cause the car is so old it isnt in the computers. So I'm kinda looking for a D.I.Y. job here. Any help would be greatly appreciated.
Old Jan 4, 2003 | 12:06 PM
drstillpatient's Avatar
man i get sick of how i hear everyday of these dealers trying to rob innocent maxima owners like us for relatively simple issues..
I think the alarm box is behind the GLOVE BOX (someone correct me if i'm wrong)...atleast thats where the master codes are written on that metal box. u may take out the glove box for easy access...do u have the keyless entry system on yours?
My GXE had keyless entry and had the SAME problem...the alarm went off ramdomly but since it only goes for 4 minutes only so as not to drain the battery...my neighbours just got used to it ...i reset the password on my keyless system using the master password and it apparently fixed it...i hope it does for u too!
Old Jan 4, 2003 | 12:13 PM
«§»Craig B«§»'s Avatar
you are wrong
the alarm is just to the left of the steering column for US cars; for Canada, it is just above the glove box
the keyless entry unit for GXEs is located just to the right of the glove box
not sure about the problem though
Old Jan 4, 2003 | 12:17 PM
No I dont have the keyless entry or the keypad. My aunt has the same year GXE Max with the keypad and it's never had a problem like this that I know of.
Old Jan 4, 2003 | 12:18 PM
CRAIG has spoken!!
thanks for the correction...
Old Jan 4, 2003 | 02:36 PM
For Future Reference For Everyone
I did all the checking I could and finally came up with something. The guy at parts said this was just the ECM. Sad part is... it's gonna cost a good... oh... $280 to just buy the damned thing. I still want to know whether anyone else has run across this and what the probable causes are, I'm really thinkin that it just isn't worth it to replace.
*sigh*
Old Jan 4, 2003 | 03:12 PM
ShOwMaX
i had the same problem with my 90 se. It likes to go off by itself 5 in the morning. After a while it just fixed itself. When my bro had the car...he nevered armed the alarm. When i got it....i always armed it. That why it use to go off by itself whenever it wants to. The alarm just fixed itself after a while.
Old Jan 4, 2003 | 04:20 PM
m_maxxy's Avatar
Craig!
Alarm module - you mean anti-theft module, right?
According to you in my car alarm module is located above the glove box (I'm form Canada). How can access it? Should I remove glove box?
And if alarm module located above the glove box then what is the module on the left under the steering column just in front of time control unit?
Originally posted by «§»Craig B«§»
you are wrong
Old Jan 4, 2003 | 04:34 PM
Originally posted by m_maxxy
Craig!
yeah, alarm = anti-theft
I've never actually done anything on a Canadian max so I can't say for sure, but according to my FSM, the alarm for Canadian maximas is directly above the glove box so I'd guess you just have to remove the glove box to get it out. There are a bunch of screws around the outside of the glovebox once you open the door. Just remove those and it should pull out. Then you'll have a wire and a "shock" holding it in I think, just remove those from the side and pull it out.
on US maximas: on left side of steering column, there is the time control unit and the stock alarm is just in front of that; on the right side of the steering column, there is the cruise control (ASCD) control unit and door lock timer in front of that (only 92-94 have door lock timer)
on Canadian models: cruise control, door lock timer, and time control unit are the same but in front of that is the daytime light control unit
Old Jan 4, 2003 | 04:39 PM
m_maxxy's Avatar
Craig!
Thanks a lot! Very complete answer.
Gonna do this tomorrow.
Old Jan 5, 2003 | 12:01 PM
totallymaxedout's Avatar
ALARM HELP 1993 MODEL...!!!
HELP..
MY GIRLFRIEND KEEPS LOOKING HER KEYS IN THE CAR ON HER 1993 MODEL..SHE HAS THE KEYPAD ON THE DOOR,BUT I CANT REMEMBER HOW TO PROGRAM THE PAD...I DID MY MOMS ABOUT THREE YEARS AGO BUT I FORGOT HOW..I HAVE PULLED THE GLOVEBOX OUT AND GOT THE MASTER NUMBER OFF THE BOX...I CAN GET THE NUMBER ENTERED AND THEN IT BEEPS FOR SOME SECONDS BUT I CANT REMEMBER HOW TO GET IT TO TAKE THE 4 DIGIT NUMBER OF OUR CHOICE..IF ANYONE KNOWS HOW PLEASE REPLY TO THIS POST
THANKS..
TOTALLYMAXEDOUT
Old Jan 5, 2003 | 12:21 PM
you should enter the 4 digit code while the beep is sounding for the 6 seconds...There was a detailed thread on this sometime back....
the search function is your friend!
Old Jan 5, 2003 | 12:27 PM
THANKS....
THANKS FOR THE INFO....I WILL LOOK AT THE OLD THREAD ALSO....
user 11122324
42
Jul 18, 2022 03:35 PM
gavin68
Sep 18, 2021 12:36 PM
HerpDerp1919
Sep 29, 2015 02:02 PM
zmcneely13
Sep 26, 2015 02:26 PM
homewrecker
Sep 24, 2015 07:01 PM
