92 GXE broken trunk latch
Old Jan 7, 2003 | 11:06 AM
john402052000's Avatar
I have a 92 GXE that I bought used. About 6 months ago the trunk would need to be shut more than once to get it to close. Now it won't close at all. I have a Chilton's for the model but the diagram of the latch system is very small. Does anybody have any links to a walk thru, or any suggestions of how to fix it, or what might have broken? Any help would be greatly appreciated.
thanks,
John
Old Jan 7, 2003 | 01:54 PM
Lordrandall's Avatar
My latch broke a while ago as well.
Try pushing the trunk all the way closed, then pull out, and press in on the bottom of the trunk where the latch is until it closes. You should hear a click. If this works you might have to lightly bend the latch section attached to the trunk to get it re-aligned.
Also check the lower part of the latch and make sure the screws that hold it in place have not come loose and let it slip down. That could also be a reason why it will not close.
Good luck!
REDinLV
Aug 15, 2024 12:30 AM
litch
123
Jan 4, 2024 07:01 PM
tarun900
19
Dec 20, 2021 06:57 PM
Socalstillen
Sep 20, 2015 11:46 PM
