Electron Bat on the Fuse Label?
Old Jan 7, 2003 | 01:39 PM
RickC's Avatar
I have something draining my battery. I put a ammeter between ground on the battery and the ground cable, (with it disconnected), and I see drain. I started pulling fuses one by one and I found the culprit to be called "Electron Bat" on the fuse panel. Anyone have any idea what that is or what it does? It is a 10a fuse.
Thanks a bunch,
RickC
Old Jan 7, 2003 | 01:49 PM
GreenMaxVE's Avatar
Re: Electron Bat on the Fuse Label?
The stereo and the clock run through that fuse, so they would drain a little power, but not enough to kill the battery. Also the interior lights and automatic seatbelts, maybe one of those has shorted.
Old Jan 7, 2003 | 04:21 PM
RickC's Avatar
Possible, but I don't think so since all that is working fine. I have a friend who is a mechanic who can look it up for me. I will check with him tomorrow to see what it feeds.
Thx,
Old Jan 7, 2003 | 04:44 PM
«§»Craig B«§»'s Avatar
for descriptions of what each fuse does, check my site
Old Jan 8, 2003 | 04:56 AM
RickC's Avatar
Craig? Your the man, great howto's on that site for the beginner.
Thanks a ton....
RickC
Old Jan 8, 2003 | 05:27 AM
Thanks a ton....
RickC
thanks, glad I could help
Old Jan 8, 2003 | 05:31 AM
RickC's Avatar
Now looking at the fuse, the list is a mile long. The clock is one of the things this fuse feeds, which was suggested before. Also the seat belt mechanism. The list includes about 7 or 8 other things. Looks like I will have fun tracing this down. But since the amperage is changing while monitoring it, I am suspecting the clock. I will pull the power to it first to see what happens. Thanks again for the information.
RickC
Old Jan 8, 2003 | 08:07 AM
eric93SE's Avatar
Thanks a bunch,
RickC
How much current was being used?
If it was only a couple hundred milliamps, then I dont think you should worry.
Old Jan 8, 2003 | 08:13 AM
RickC's Avatar
I think the highest was around 198 mA. But it would jump around. It would show about 50mA, then 150mA, then 198mA, then repeat the cycle. If less than 200mA shouldn't be a problem, then maybe it's something else and I'm on the wrong track, but something will kill the battery in less than 3 days if I don't start and drive the car.
Thx,
RickC
Old Jan 8, 2003 | 08:25 AM
eric93SE's Avatar
Thx,
RickC
How old's the batt.?
Old Jan 8, 2003 | 08:33 AM
RickC's Avatar
It's about 3 years old from what I am told.
Old Jan 8, 2003 | 08:39 AM
eric93SE's Avatar
???From what you are told???? Is that what the previous owner has told you!!
GET A NEW BATT.
Old Jan 8, 2003 | 08:48 AM
RickC's Avatar
Yes, previous owner said it was three years old. The previous owner is my mother-in-law. I sold the car to her in 94. I bought it new originally. I am trying to get the car back to top shape considering the low miles.
Old Jul 9, 2009 | 12:39 PM
heckum's Avatar
electron bat fuse
so now that you found the source to be electron bat fuse how did you solve the problem and what did you find?
Old Jul 9, 2009 | 12:42 PM
vernk's Avatar
turn your dome light switch to off and see if the draw drops, just a thought
Old Jul 9, 2009 | 01:22 PM
RA121625's Avatar
I say get the battery tested, batteries can sometimes die before their recommended usage period, for example mine only lasted about 2 years until the voltage started to drop slowly. If so then get it replaced.
Old Jul 10, 2009 | 09:50 AM
tresboi's Avatar
LOL Gents, this thread is 6 1/2 years old. I'm sure that battery has long since been replaced
magiconthetire
Oct 26, 2015 09:03 PM
leatherneck
Sep 30, 2015 09:16 PM
conansriver
Sep 16, 2015 12:17 PM
mikebla
Sep 3, 2015 05:37 PM
