the clutch
Old Jan 21, 2003 | 06:32 PM
nagal's Avatar
Dreams of a RB26DETT
the clutch
hey well thanx for the good welcome to the max forum!! well i got a problem the clutch pedel is stickin or not getttin the spring action and i dont know much about hydralck clutchs so i need some help i put brake fluids in and is is still not going
Old Jan 21, 2003 | 07:38 PM
nstymax93's Avatar
did you bleed the system too? Maybe your slave unit needs replacing or your clutch master cylinder!
Old Jan 21, 2003 | 07:56 PM
«§»Craig B«§»'s Avatar
look for leaks - trace it from the clutch master cylinder through the clutch hose on top of the tranny to the slave cylinder near the battery
also check inside the cabin for leaks near the upper part of the clutch pedal
and if there aren't any leaks, you may just need to bleed the system (bleeder screw is on the slave cylinder)
user 11122324
42
Jul 18, 2022 03:35 PM
Mar 12, 2020 12:06 AM
spencerwh1
Jun 30, 2016 05:44 AM
BkGreen97
Apr 2, 2016 05:47 AM
carlosvq30
Sep 26, 2015 09:44 AM
