blew the head gasket
Old Jan 23, 2003 | 06:30 PM
xtrip's Avatar
well, i ran my vg very hot one night. drove it like 2 miles with no water. refilled it, and everything was fine. then it started losing water about a week later.
i have recently replaced the waterpump and thermostat.
but this time the water is leaking out in between the auto tranny and the engine. there isnt any smoke comming out of the exhaust tho.
anybody have a clue what this all means?
im thinking its the head gasket.
Old Jan 24, 2003 | 04:33 AM
Pervis Anathema's Avatar
The cylinder heads are aluminum. You probably warped them and blew the head gasket. Therefore, you will need new cylinder heads. $$$
Old Jan 24, 2003 | 07:35 AM
eric93SE's Avatar
Re: blew the head gasket
Could be a freeze plug. If I were you I'd try some of that radiator coolant stop leak stuff, so long as its not leaking really fast it should work. The stuff is way cheaper than doing the head gasket, and it should last really long so long as you don't flush the radiator (that'll remove the sealing stuff).
Old Jan 24, 2003 | 11:11 AM
male's Avatar
Don't use the stop leak stuff. Clogs radiator and heater core. Find the leak, then replace the freeze plug if that's what it is. Is coolant going out the tailpipe? Or is it dripping out onto the ground?
Old Jan 24, 2003 | 05:17 PM
eric93SE's Avatar
I had a leak and used the saw dust looking pellets, solved my leak and no problems. I broke the pellets until they were a fine powder then introduced them into the radiator. Sure its not the best choice, but I currently dont intend to pull the top end of the engine apart (at least not right now ).
Old Jan 25, 2003 | 10:09 AM
xtrip's Avatar
i just took the car into the shop today, they ran some compression checks. looks like the topend of the motor is fine. mechanic , and i think its a freeze plug. ones on the back side of the motor. looks to be 500+$.
Old Jan 25, 2003 | 01:21 PM
eric93SE's Avatar
OR you could spend $3 and use the pellets.
Old Jan 25, 2003 | 02:57 PM
xtrip's Avatar
its beyond the pellets at this point.
the copper fluid ran right thru the leak in the block.
it sealed for like 15 minutes.
then it started pouring.
this is my primary mode of transpo. so i need it repaired. not just a quick fix
knight_yyz
Nov 1, 2015 01:34 PM
worldwiderecognized
Sep 30, 2015 01:16 PM
jaydot901
Sep 29, 2015 01:18 PM
