Electrical / Rear Brake Lights Problems
Old Jan 24, 2003 | 08:46 AM
tropher13's Avatar
I have a 1992 Maxima Se. Recently I discovered that the rear brake lights are no longer lighting when the brake pedal is depressed. Additionally, I an unable to shift out of Park without using the manual release, even though the brake pedal is being pressed.
Anyone have any insight into this problem. Could it be as aimple as a brake pedal switch or am I looking at major problems.
Any help is appreciated.
Old Jan 24, 2003 | 09:13 AM
«§»Craig B«§»'s Avatar
Re: Electrical / Rear Brake Lights Problems
if they both occured at the same time, I'd guess it's something with the brake switch
it should be a switch near the upper part of the pedal and it'll have a little pin switch that moves in and out (gets released when the brake pedal is pressed I think), probably just replace that and it should be ok
you have 2 switches there I believe - one for brake lights and stuff, other for cruise control cancel
Huttig2009
Sep 25, 2015 03:31 PM
JMag90
Aug 25, 2015 09:17 AM
Samedi
Aug 13, 2015 04:05 PM
RealityCheck
Aug 5, 2015 06:18 AM
