Replacing Fan and Motor
Old Jan 24, 2003 | 06:16 PM
JD's Avatar
JD
Fan blade and motor need replaced on the passenger side. Haynes mauanl says to drain the radiator and remove hose. Looks like there might be enough clearance without having to go that far. Anyone else change one?
Old Jan 24, 2003 | 06:28 PM
max4me's Avatar
Do you need a fan and motor? If so I can sell you one and let you know about your question as I practice removing it from my junker.
Old Jan 25, 2003 | 03:13 AM
arges's Avatar
Re: Replacing Fan and Motor
If you R speaking of the rad fan, then why don't you simply remove the shrowd holding the fans. That's what I did when I removed the broken studs in my front exhust manifold. Comes off real easy = six bolts I think, but remember to lable the two electrical connectons, top and bottom.
Good Luck
Stephen
Old Jan 25, 2003 | 06:39 AM
darrick's Avatar
Dallas Nissan Enthusiast
I Need fans bro
dude I need fans BAD do you have the set (drivers and pass) let me know
MattWithTheMaxima
Jun 30, 2017 01:06 PM
vingodine
45
May 21, 2016 12:46 PM
jerrod99_se-l
Aug 24, 2015 10:24 AM
doobadoo
Aug 15, 2015 06:43 PM
kirkhilles
Aug 8, 2015 10:53 AM
