Who Has The Most HP?
Old Feb 1, 2003 | 03:18 PM
Soul Fly
i'm about to hit 170 w/ k&n and exhuast...how about yall?
Old Feb 1, 2003 | 03:34 PM
DA-MAX's Avatar
Eat, sleep, and sh*t 2JZ
Re: Who Has The Most HP?
bah....crank HP is the devil!!! it makes you think the car is that fast when its actually not while crank HP might be 170, at the wheels you're only in the 120s probably
Old Feb 1, 2003 | 05:09 PM
PATRICK94SE's Avatar
I started out with 20 more then that
Old Feb 1, 2003 | 05:27 PM
dmontzsta's Avatar
Ford Only.
how do you know it will give you 10hp?
Old Feb 1, 2003 | 05:28 PM
subs1000w's Avatar
im guessing my ve has about 170 at the wheels with cone filter, y-pipe, underdrive pully and advanced ignition timeing. i do plan on having it dynoed very soon because i just got the filter, y-pipe and udp on tues and have an ultra light flywheel on the way which i hope will give about 5 more
Old Feb 1, 2003 | 06:03 PM
dmontzsta's Avatar
Ford Only.
you might even be closer to 190hp. Since stock VE's put down about that much.
Old Feb 1, 2003 | 06:17 PM
subs1000w's Avatar
i always thought a stock ve was inbetween 155 and 160
Old Feb 1, 2003 | 06:25 PM
dmontzsta's Avatar
Ford Only.
5 speeds are usually around 160-170 depeding on condition. I believe Randy dyno'd at 167hp stock.
Old Feb 1, 2003 | 06:50 PM
nismo-max500's Avatar
i do
with my twin turbo, awd maxima!
jk
Old Feb 1, 2003 | 06:54 PM
dmontzsta's Avatar
Ford Only.
To give an answer to this thread, I would say anyone with boost...so
4signs or Max O/D
Old Feb 1, 2003 | 09:15 PM
Soul Fly
Old Feb 2, 2003 | 09:03 AM
Chris91SE's Avatar
Eagles Fan 4 Lyfe
advertising math
dyno the car now and then afterwards and tell us your results..
Old Feb 2, 2003 | 11:22 AM
Jeff92se's Avatar
I'm needing a caw
Instead of asking, try searching.
