hesitation, then pull, please help!
Old Feb 11, 2003 | 08:40 PM
J93MaximSE's Avatar
I have a 93 VE. This problem happens quite often. Lets say im on the gas about 1/3 throttle. the rpm up to about 2800 to 2900 rpm is very slow and hesitant but when it gets up past 3000 it pulls like it normally should. this happens in all the gears. i was wondering if anyone knew what could be going wrong. could it be my timing, my fuel filter, my injectors, or even something else??? please help and thanks for the info.
Old Feb 12, 2003 | 07:31 AM
Spipedong90's Avatar
Re: hesitation, then pull, please help!
Welcome to the VE Bullsh** club. Take a look at the sticky called "heat soak gone with new knock sensor". It may be of some use to you.
Old Feb 12, 2003 | 08:53 AM
Maximan190's Avatar
thats VE power- below 3k its dead, from 3k-redline it flys
Old Feb 12, 2003 | 01:14 PM
J93MaximSE's Avatar
i was thinkng it was my KS u i was hoping not. its pulled better th this before. i also have a pulley and intake. so im confused. because stock it was crap below 3k and it got better with those mods but now i seems to be crap again. i dunno. thanks for you help though!
Old Feb 12, 2003 | 02:04 PM
subs1000w's Avatar
yeah i have the same problem and i will be changing my ks over the summer but i advanced my ignition timing and its not as noticable, i can still tell well its happening but its definitly more responsive in the low end
Old Feb 12, 2003 | 05:39 PM
eric93SE's Avatar
Have you ever replaced the ingition coils? if you have more than 70k on them, then you should replaced them (all six of them) www.courtesyparts.com This is a part of a nornal ignition tune up. But be prepared to cough up $300
HerpDerp1919
Sep 29, 2015 02:02 PM
Sep 27, 2015 08:37 AM
