Can Anyone help me?!?!?
Old Jan 9, 2001 | 11:37 PM
psing23's Avatar
i gotta change my speed sensor in my 1990 Maxima SE... i will be getting it very shortly... has anyone done this? can anyone help me with this? anyone have any instructions? please help... thanks
-danny
Old Jan 10, 2001 | 01:53 PM
Chris Gregg's Avatar
Get Off My Lawn
I assume this is for the 3rd gen? The device is located on the driver's side. Find the oil filter, it should be right below it sticking up from the tranny. One screw holds it in, a philips, or you can use a 10mm which I would recommend using to avoid stripping. Once screw is removed, simply pull out of transmission, unplut from harness, then reverse process for new unit. If it takes more than 5 minutes, your having too much fun!
