Windshield Washer Bottle / Way to small: Any Retrofits? /91 SE
Old Feb 21, 2003 | 06:10 AM
patrick leber's Avatar
The winshield washer resevoir doesnt hold enough in my 91 SE. One or two squirts and its empty.
Does anyone make a larger unit or do any other models have a large capacity tank that I can fit in there. There isnt much room either.
Any thoughts folks??
Old Feb 21, 2003 | 06:50 AM
N34JZ's Avatar
Needs non-Maxima Friends
when I had mine I never had this problem and I used the washers a lot. Mabey you have a leak?
Old Feb 21, 2003 | 07:01 AM
Nope, no leak
No leak , its that i cant get used to the small capacity - it must be under 1 liter.
My Porsche holds over a gallon, the benz is large too. I NY during the winter to need alot with all of the slush & road grime flying around.
Old Feb 21, 2003 | 08:10 AM
DanNY's Avatar
Ad·min·is·tra·tor
the tank holds about a gallon of washer fluid.
if you need more than that you might want to use better wipers because for me one spray two wipes and it's clear. yeah this is in NY slush and etc too.
you sure u don't have a leak somewhere in the line..(ie 1/2 goes on the ground 1/2 goes to your windshield)
Old Feb 21, 2003 | 08:42 AM
N34JZ's Avatar
me too, I have the CF hood now but before I used mine alot. I filled it up in january and went all the way till august with out filling it up again and Im sure there is still some in there.
Old Feb 21, 2003 | 09:19 AM
nubiannupe's Avatar
OG Maxima.org Member
Patrick,
It's my thought that you're mistaking the reservoir filler tube as the actual reservoir itself. Reason being, there's no way on God's green earth that one or two squirts will empty out that bottle! I don't care HOW you look at it, it's physically impossible unless you've got a serious leak (which you say you don't). It takes practically a whole gallon of fluid to fill it.
If you're only getting a couple of squirts out, you might want to check your lines coming out from the nozzles for obstructions or possibly your washer pump for any faults there. And check your nozzles, also.
Chilton's and Haynes manuals (and FSM's too) will be your friend in this endeavor.
Otherwise, move the y-bong away from the engine!
(btw - I was just kidding about the y-bong thing....)
02PearlSE
Feb 1, 2016 12:37 AM
03VQMAX
Nov 10, 2015 03:39 PM
Excalibur23
Oct 13, 2015 04:33 PM
220k+ A32
Sep 23, 2015 03:38 PM
Vistance
Sep 17, 2015 05:17 AM
