Question on changing the gauge bulbs???
Old Feb 24, 2003 | 06:27 AM
2 tha MAX's Avatar
I know some people have tried it. I was just wondering how many bulbs I will need for it? Also I think the bulb size is 194, if this is wrong please correct me? Thanks for your help.
Old Feb 24, 2003 | 06:31 AM
DA-MAX's Avatar
Eat, sleep, and sh*t 2JZ
pretty sure there are 4 194 bulbs back there
Old Feb 24, 2003 | 06:40 AM
2 tha MAX's Avatar
ok thanks for the help.
Old Feb 24, 2003 | 06:41 AM
2 tha MAX's Avatar
Are they hard to change? I know how to get to the gauges but then Are there just screws that hold the bulbs in?
Old Feb 24, 2003 | 06:50 AM
DA-MAX's Avatar
you'll see 4 little brown "twist caps" on the back of the gauges...just turn and pull it out and the bulb is in it. its really easy!
Old Feb 24, 2003 | 08:28 AM
2 tha MAX's Avatar
Old Feb 24, 2003 | 05:21 PM
Mike S.'s Avatar
aren't they 168? I'm always confused by this. I was thinking of getting some 194Superwhite PIAA LED's, but I'm not sure if the LED's are bigger than a regular 194 bulbs?
Old Feb 24, 2003 | 05:30 PM
DA-MAX's Avatar
I never really figured the difference between 168 and 194...I doubt there are any major differences to complicate this install! most sites list them with a "/" in between (ie- 194/168 bulbs). I know for sure I put 194s in my gauge lights last year though.
Old Feb 24, 2003 | 05:39 PM
midnight's Avatar
Has anyone put blue ones back there? Did it look good? Got any pics of it done?
Old Feb 24, 2003 | 05:45 PM
Tim93se5sp's Avatar
From what I could tell, there is no difference between 168 and 194 bulbs. They are all cross referenced as interchangable on the websites selling bulbs that I came across.
However, I do not recommend LEDs in the instrument cluster. I tried the exact LED you are talking about (PIAA), and while the color was terrific, the light dispersion was poor. I think it has to do with the inherint directional light that the LEDs put out, while a filament bulb will spread out in all directions better. I have some polarg bulbs on order, and I expect them to be much better. They are pictured here in a 240sx cluster:
http://www.importcarpartsplus.com/Blue1.jpeg
Hope that helps
-Tim
Old Feb 24, 2003 | 06:11 PM
pr1maxima's Avatar
Re: Question on changing the gauge bulbs???
yes there 194 bulbs back there. but the problem is that the back of the guages has a green covering over the back of it if you have a gxe. the only way to get it off is to sand it off. i dont know if the led will work right but the blue lights will eventually fade. it was a good idea i thought at first also but it ended up just being a pain just buy the reverse indilow guages from south west auto works for 55 dollars you will be much happier. trust me. just my 2 cents
Old Feb 24, 2003 | 07:39 PM
Spipedong90's Avatar
ngthing did it.
http://images.cardomain.com/installs...0_137_full.jpg
xUNIxPanther
Dec 6, 2020 09:08 PM
homeyclaus
Sep 3, 2015 06:15 PM
YourLocalAsian
Aug 17, 2015 02:33 PM
acw
Aug 13, 2015 12:50 AM
RealityCheck
Aug 5, 2015 06:18 AM
