Horrific Dyno Results!
Old Feb 27, 2003 | 06:00 PM
Soul Fly
OK - It wasnt at all what I was expecting...even the dyno guy said there's a leak in a vaccum hose or a break. (same thing) Look at how the lines jump down and up... WTF could that be?
Any help would be great! D-sta, c'mon...dont flame me
Old Feb 27, 2003 | 06:20 PM
DA-MAX's Avatar
Eat, sleep, and sh*t 2JZ
I don't see a picture
Old Feb 27, 2003 | 06:24 PM
N34JZ's Avatar
Needs non-Maxima Friends
hp 128.4
tq 148.8
damn da-max you were the closest
soul fly thats not horrible, the car is 10 years old (or more) it needs some work, you werent going to get more than stock, I didnt think more than 110 so you did better than my expectations
Old Feb 27, 2003 | 06:29 PM
Nismo87SE's Avatar
What mods does your car have? That power curve isn't smooth at all, almost like there is a miss-fire somewhere. If your car is an auto and without a Y pipe that is what I'd expect. My 87se dynoed 112whp/140wtq with just a KN panel filter and it makes 152hp/168tq @ crank. You should check your ignition and fix any vaccum hoses that are cracked or old.
Old Feb 27, 2003 | 06:30 PM
Soul Fly
yeah jason, 13 yrs and counting I think i hafta change my fuel filter, god knows when the last one was changed...
BUT HEY - AT LEAST IT'S A GOOD PIC!!
(I'm on the right if anyone's wondering)
Old Feb 27, 2003 | 06:35 PM
Soul Fly
K&N Pop charger, and 3A Racing muffler - NGK plugs-->?? Would that make a difference?
BTW - Thats to the wheels
Old Feb 27, 2003 | 06:36 PM
eric93SE's Avatar
Have you done a full ignition system tune up yet?
Its also possible that there is a problem with one or more injectors.
Old Feb 27, 2003 | 06:40 PM
DA-MAX's Avatar
Thats a great run for your mods!!! don't be disapointed! get it fixed and maybe you could pull out 130+
Old Feb 27, 2003 | 06:44 PM
Soul Fly
Get what fixed? My fuel filter? Tune up?
Eric93SEHave you done a full ignition system tune up yet?
No tune up in a while - I got NGK plugs back in october tho... what all will come in a FULL ignition tune up??
Old Feb 27, 2003 | 06:46 PM
D-sta's Avatar
Not bad soul fly, not good either. You will run a lot better when you do a tune up and stuff. I wont flame you enough that dyno result sheet should have you depressed enough...just kidding
Old Feb 27, 2003 | 06:48 PM
eric93SE's Avatar
Distributor cap/rotor (worn out, shorting out), ignition wires (they can be shorting out), maybe a new coil(you can get one that will put out higher voltage/current).
You can also clean all the ground wires in the engine compartment and on the alternator and battery.
Old Feb 27, 2003 | 06:56 PM
DA-MAX's Avatar
and advance the timing will you're at it.
Old Feb 27, 2003 | 07:07 PM
89sks's Avatar
Got any more info on the hotter coil for the VG?
Old Feb 27, 2003 | 07:10 PM
eric93SE's Avatar
MSD makes a solid state ignition system for the vg to give a stronger spark. Or you can get an old style coil upgrade.
Get good ignition wires, that give a lifetime guarnetee and are at least 8mm thick insulation.
Old Feb 27, 2003 | 08:18 PM
Chris91SE's Avatar
Eagles Fan 4 Lyfe
about what i expected to see
Old Feb 27, 2003 | 08:29 PM
James92SE's Avatar
2 VE's are better than one!
Do I see an Impala in the background?
Old Feb 27, 2003 | 09:39 PM
D-sta's Avatar
Maybe the dyno doesn't like the way your car smells
All these scented trees must've been slowing you down.
Old Feb 27, 2003 | 09:54 PM
NismoDrew91SE's Avatar
lol, thats too funny
Old Feb 27, 2003 | 10:13 PM
Matt93SE's Avatar
STFU n00b!
that's about average for a VG auto.
the curves are very lumpy though.. you've got a problem somewhere. what's weird is how they're in regular patterns though. I'd say you've definitely got some sort of engine problem to cause those. don't know what it is, but it's something. possily a leaky vacuum hose or exhaust leak which causes resonances in the system... it's obviously something based on RPM that's causing the problem.
(a vacuum leak on the engine will do that to some effect, because the leak is only a problem at certain rpm...)
Old Feb 28, 2003 | 05:08 AM
89sks's Avatar
What do you mean by old style, the cylindrical ones, like Accel makes that are yellow or chrome? Pertronix makes one called Flamethrower that is similar. If these are the ones your talking about I guess you'd have to relocate them somehow to secure them?
Old Feb 28, 2003 | 10:12 AM
eric93SE's Avatar
Yup that what I meant, the original coil is just a high voltage transformer. The stuff from MSD is solid state rectifying.
If you were to get an excel or whatever, then you would just remove the original and put the new one in its place. I would reccomend cleaning all the old connectors on the coil (whether new or old) b/c there is still low voltage feeding the coil and those connectors should be free of corrosion. I think it should be pretty worth while for the performance stand point on the vg.
Old Feb 28, 2003 | 10:21 AM
DA-MAX's Avatar
you sure about that?? most single coil ignition systems from Accel to MSD utilize the stock coil, not replace it. the aftermarket coils included in those kits piggyback off the stock coil.
Old Feb 28, 2003 | 10:40 AM
89sks's Avatar
I know you can get that older type at Pepboys but its cylindrical in shape and doesnt match the shape of the rectangular oem one. Have you replaced yours this way or did you say you got the whole msd system? I had done this with my 1st gen rx7, but the oem coil was the same shape as the $27 Accel ones at Pepboys. It did help it out noticably.
Old Feb 28, 2003 | 10:45 AM
Soul Fly
YES...it IS an Impala! GOOD EYE!
Trees are the best invention for my rear view mirror. haha - you know you love it.
Umm...I'm going to check my distributor/ignition system right now. Hm...guess I'll hafta get my SC soon
Old Feb 28, 2003 | 12:15 PM
eric93SE's Avatar
I didnt know that, you must be right then. I have a VE so I havent looked into ignition upgrades that much.
so if anyone (vg) is looking into upgrading their coil then they should do some research.
89sks: The shape shouldnt matter, you have to make it fit . Just make sure it compatable with you system.
Old Feb 28, 2003 | 12:34 PM
eric93SE's Avatar
here is an example of a solid state upgrade: http://www.suprastore.com/hkstwinpowig.html
Old Feb 28, 2003 | 12:36 PM
eric93SE's Avatar
I saw a third gen vg with this unit, he said his fuel economy went up like 2mpg, I dont remember what he said about power.
Old Feb 28, 2003 | 03:27 PM
Taegost's Avatar
REALLY? Damn... I was disappointed when I dyno'd at 135hp and 175ft-lbs... I only have an intake, too... (Muffler doesn't count, it's just loud on a stock exhaust)
Old Feb 28, 2003 | 03:45 PM
Soul Fly
GUYS!...I took off the cover over my spark plug wires (not 100% sure what it's called) and unscrewed 2 out of the 3 srews holding that metal cover on. I was gona look at the distributor (i think) to see what was goin on w/ it...but I couldnt get that damn 3rd screw loose - I advanced my timing a weee bit, didnt notice a big difference....
Old Feb 28, 2003 | 05:42 PM
eric93SE's Avatar
Dude I can't believe you didnt do a partial/full tune up before going to the dyno . BTW how much the the dyno run you $$.
Old Feb 28, 2003 | 05:57 PM
Soul Fly
$50 for 3 runs...print out of the best of 3
Old Feb 28, 2003 | 07:44 PM
Soul Fly
do you think you're about the same...or do you have a VE?
TallTom
57
Oct 14, 2025 05:16 PM
Apr 16, 2020 05:15 AM
Mar 12, 2020 12:06 AM
mkaresh
Mar 12, 2018 06:48 PM
Sep 27, 2015 08:37 AM
