any one tint their own windows???
Old Feb 27, 2003 | 06:17 PM
StreetTrixE4six's Avatar
every car i've ever owned has had tinted windows and i really feel naked w/o them. since the maxima is my commuter/spare car, i don't really feel like spending $180 for tints. so i bought 25% tints and a tint kit. anyone ever do this themselves? have any tips for me? TIA
Bryan
Old Feb 28, 2003 | 05:56 AM
MaximaBalla's Avatar
Why are there 3 of the same responses?
Old Feb 28, 2003 | 06:13 AM
in case i didn't understand it the first time he typed it
Old Feb 28, 2003 | 06:15 AM
89sks: thanks for the advice, i'll let u guys know how it comes out
Old Feb 28, 2003 | 06:22 AM
shock211's Avatar
i've tinted a car once and because of the patience required i probably will never do it again.
it's all about the squegee! you have to be patient and gently use the squegee to squeeze the water out from in between the window and the tint. good luck! and take your time, it's not easy.
Old Feb 28, 2003 | 06:48 AM
DanNY's Avatar
Ad·min·is·tra·tor
tips:
clean EVERYTHING!!! even that weatherstriping part that seals up the glass. when u spray down the soap mix dirt comes out of everything.
if you have existing tint...make sure to clean all of it off. use a white (teflon) scrubbing pad.
also i highly recommend getting professional quality tint. i'm not talking about the off the rack in pep boys special. the pro stuff sticks better and looks better when it's done.
make sure u have a clean area to cut tint...remember..clean clean clean.
sharp knives/blades are a must. use a new blade for every car..if not every other window. having a blade snag on tint when you're cutting just means more wasted material.
get some good squeegees...big and small. big for the big areas and small to finess it. teflon hardcards are quite useful and they can be trimmed to suit your needs.
if you'll be doing just one car and that's it...i say go have someone do it professionally. if you want to do it for a few cars or really want to do it on the side/learn how to do it then prepare to spend $.
to cut 2 windows at the same time take two piece of tint and lay them on top of each other (tint to tint) and cut. you'll get both left and right side with one cut...but if u mess up u just wasted twice the amount of tint.
Old Feb 28, 2003 | 07:25 AM
89sks's Avatar
Sorry about the triple post! I tried to send it and I got no response, so I stopped and tried again and still nothing. Then finally I got a response server busy. I guess it did send each time.
I agree with what one of the guys said, make sure you really clean the glass. You can also get a little kit for a couple of bucks with a squeege or however you spell it, its worth it!
Good luck.
Fbana41
Aug 29, 2016 12:18 PM
D Mason
Jun 21, 2016 04:43 AM
lrb6805
Sep 24, 2015 05:03 PM
