A few questions
Old Mar 9, 2003 | 01:02 AM
1990MaximaGXE's Avatar
A few questions
I have a few questions with my maxima
1- i have a broken drivers side mirror are there any after market mirros (m3's) that fit our cars? also how hard is it to install the heated mirrors instead of the stock ones i have now?
2- my power antena doesnt go down how do i fix this?
3- after removing my door panels i broke a few of those plastic clips that hold it on where can i go to get replacements?
thank you and also i searched the first 1500 posts and used the search
Old Mar 9, 2003 | 06:22 AM
Cincy94Max's Avatar
1. M3 mirrors fit, but I'm not sure which year you need.
2. Replace the antenna motor. The mast is most likely still usable, but the motor is probably burnt out. If you can hear the motor running when the antenna tries to go up and down, then the string that is inside the mast is broken. Your best bet is just to replace the whole thing with OEM or an aftermarket rubber antenna. For OEM: www.courtesyparts.com is a good place. You get a 20% discount on all OEM parts if you say you are a member of Maxima.org.
3. Did you completely break the clips, because I have broken layers off of them, but never the whole thing. Either way, you could contact www.courtesyparts.com and ask them. Maybe a dealer near you has some.
Old Mar 10, 2003 | 11:20 AM
Thank you verry much
Unclejunebug
Apr 2, 2016 05:42 AM
Stagnet04
Oct 11, 2015 08:16 PM
Socalstillen
Sep 26, 2015 12:01 PM
