VG problem
Old Mar 9, 2003 | 10:01 PM
grody's Avatar
VG problem
Hi all.
I've been having a bit of a problem with my '90 GXE over the past few days. At about 2k RPM, I've got a rattling noise and a slight power loss. It happens more noticably under load. It happens regardless of gear and vehicle speed. If I accelerate moderately from a stop, the noise and power loss occur from ~1900 RPM to ~2100 RPM. Thanks, and I hope I've been descriptive enough.
Old Mar 9, 2003 | 10:32 PM
drstillpatient's Avatar
Re: VG problem
Originally posted by grody
Hi all.
Lately i have been having the same issue...and at the same RPMs you said and in the same conditions too...either going uphill or under some other load...
i have a leaking stock y pipe and i thought maybe it was the leak that was causing the power loss.
Old Mar 10, 2003 | 12:16 AM
Torres's Avatar
did u check ur O2 sensor?
and check the heat shield around the y-pipe..it could b loose
and check the knock sensor too....
hope this helps
Torres
Old Mar 10, 2003 | 05:31 AM
89sks's Avatar
Re: VG problem
Hi all.
Could it be a bad CAT with chunks of stuff rattling around and moving around in a way to restrict exhaust flow? Just an Idea, not sure if thats possible.
litch
123
Jan 4, 2024 07:01 PM
jmlee44
Oct 2, 2022 02:13 PM
gavin68
Sep 18, 2021 12:36 PM
HerpDerp1919
Sep 29, 2015 02:02 PM
homewrecker
Sep 24, 2015 07:01 PM
