went in for a clutch install. . .
Old Mar 14, 2003 | 03:22 PM
ocMax's Avatar
Well. I took my MAX to the trans shop this morning for a clutch and rear main oil seal quoted at $550. I get a call later from the shop saying i need 3 new trans mounts, and a new master/slave cylinder. The mounts are believable but im not to sure of the master/slave replacment. I mean come on my brakes work fine. theres no visibal leaks. Oh well i did it anyway. it cant hurt the car, and I plan on keeping it for a while to so I guess I would have had to do it sooner or later.
Old Mar 14, 2003 | 03:25 PM
Jeff92se's Avatar
I'm needing a caw
Uh, clutch master and slave or brake master and slave?
Old Mar 14, 2003 | 03:31 PM
ocMax's Avatar
as far as i knew they were the same??????????
Old Mar 14, 2003 | 03:36 PM
Jeff92se's Avatar
I'm needing a caw
Ah nope. If you press the brake, you use the brake master clyinder and the equivlent of a slave cylinder on the calipers. If you press the clutch pedal, you use the master clinder for the clutch and presses fluid though the slave mounted on the tranny.
You probably had the CLUTCH master and slave replaced. Probably a good thing anyway.
Old Mar 17, 2003 | 09:36 PM
AET's Avatar
AET
Sounds like you got a good quote on the clutch and rear main. I paid $538 to have a shop install a clutch, parts I brought them and my flywheel resurfaced.
Old Mar 17, 2003 | 09:50 PM
NismoDrew91SE's Avatar
yah same here. from what i hear when you replace the factory clutch always good to replace the master//slave cylinders too
user 11122324
42
Jul 18, 2022 03:35 PM
Mar 12, 2020 12:06 AM
BkGreen97
Apr 2, 2016 05:47 AM
carlosvq30
Sep 26, 2015 09:44 AM
jds22
Sep 4, 2015 01:52 PM
