Camber kits
Old Mar 15, 2003 | 08:31 PM
pest2001's Avatar
Camber kits
i tried to search but the search function is shut down so i was wondering where i can find a front and rear camber kit for my max
thanx
william
Old Mar 15, 2003 | 08:38 PM
Michael's Avatar
Back in a 3rd Gen.
Re: Camber kits
thanx
william
candiman makes an adjustable camber plate for the front. Or you can get the camber bolts.
for the rears just go to a junk yard and get the adjustable link off of a max and put it in place of your solid one. Our suspension comes with an adjustable (for toe) and a solid parallel link but if you replace the solid one you can adjust camber (I did this btw)
while your at it go ahead and replace all the bushings. its not too expensive and is probably worn pretty good (I did this too).
Old Mar 15, 2003 | 10:14 PM
Lordrandall's Avatar
Re: Re: Camber kits
Michael, I don't think Mike sells those anymore.
Old Mar 15, 2003 | 10:35 PM
Matt93SE's Avatar
STFU n00b!
Even if he does, they're not worth putting on the car. I had to do another $100 in modifications to them just to make them work.
Old Mar 16, 2003 | 08:27 AM
Michael's Avatar
Back in a 3rd Gen.
Re: Re: Re: Camber kits
OK I just remember reading some of his posts when I was searching about camber bolts and it seems like he was pushing them not that long ago but you can never tell with searching...it may have been 2 years ago .
I went with the camber bolts up front.
Old Mar 16, 2003 | 01:51 PM
scott92282's Avatar
Re: Camber kits
thanx
william
I have a set of rear camber adjustment arms BRAND NEW that I can sell you. Email me if you are interested.
Old Mar 16, 2003 | 04:13 PM
gdmaxse's Avatar
is there any way to adjust the caster or any kit that can adjust it?
Old Mar 16, 2003 | 05:36 PM
James92SE's Avatar
2 VE's are better than one!
Hum I dont know about you guys but I have no rear camber problems at all. Neither on the auto nor on the 5spd. Perfectly even wear and I'm on Intrax/Tokico.
Now the fronts are kinda bad but I just got some camber bolts. Michael...did the bolts get your fronts in spec? Or remotely close?
Old Mar 16, 2003 | 05:45 PM
lowmax4's Avatar
where can you get the bolts and will they work with sprints?
Old Mar 16, 2003 | 05:57 PM
James92SE's Avatar
DA-MAX hooked me up with mine but here...(if I remember the site correctly)
www.specprod.com
Old Mar 16, 2003 | 06:28 PM
lowmax4's Avatar
I found three different kits on that website is there one that is better than the rest? or should I just buy the cheapest one?
Old Mar 16, 2003 | 07:39 PM
Michael's Avatar
Back in a 3rd Gen.
I havent had it aligned yet. I need to replace a tie rod and do my wheel bearings first.
My rear was wearing real bad but I found out when taking the parts out to rebuild them that it was because the suspension member was bent a little...I assume from the wreck the guy had. I went ahead and put the adjustable link in since I already built it and figured it was better to have anyway.
I have the Eibach front bolts that I got from another org member that was parting out his car (edgeproduction) but they were new in the package. I am not sure where the best place to get them would be though.
Old Mar 16, 2003 | 07:42 PM
gdmaxse's Avatar
www.nopionline.com has both the front bolts and the adjustable rear parallel links
Old Mar 17, 2003 | 02:05 PM
Strrrive's Avatar
I got a set from the people that did my alignment. I never used it.
Old Mar 17, 2003 | 04:27 PM
lowmax4's Avatar
want to sell them?
Apr 16, 2020 05:15 AM
Kyle Lee Cleveland
Sep 28, 2015 07:58 AM
Pied
Sep 26, 2015 03:29 PM
