does the VE come stock w/forged pistons?
Old Mar 15, 2003 | 10:38 PM
MadMax92's Avatar
just wanted to know if the VE comes stock with forged pistons or not. Advanced auto sells forged pistons and thats all. I was just wandering thanks.
Old Mar 15, 2003 | 10:40 PM
DA-MAX's Avatar
Eat, sleep, and sh*t 2JZ
Re: does the VE come stock w/forged pistons?
no
and what brand forged pistons does Advance Auto offer???
Old Mar 15, 2003 | 10:43 PM
MadMax92's Avatar
Re: Re: does the VE come stock w/forged pistons?
Originally posted by DA-MAX
no
Let me check and I'll get back to you.
I know they also sell chromoly piston rings or something chrome theyre supposed to be higher quality so I;m going with those
Old Mar 15, 2003 | 11:06 PM
DA-MAX's Avatar
Re: Re: Re: does the VE come stock w/forged pistons?
chromoly pistons rings?? I think you mean rods ...thats some pretty custom stuff for Advance to carry..."offshelf" VE internals, thats hard to believe, make sure its for your car, before you shell out the cash.
Old Mar 16, 2003 | 05:06 PM
eric93SE's Avatar
I've seen the moly piston rings available before, their totally worth getting. I think I saw them at carparts.com
Old Mar 16, 2003 | 07:54 PM
Michael's Avatar
Back in a 3rd Gen.
yeah they last a long time but are hard on the cylinder walls. I had some in a 350 and the walls were worn more than you would think for the miles on the motor but it didnt smoke or anything...I pulled it down to swap heads.
I have had other people tell me this too.
Old Mar 16, 2003 | 08:39 PM
DA-MAX's Avatar
so they actually make them...wow, but it would seem that the cons far outweigh the pros. I mean since the rings are the strongest seal between the walls and the piston and with chromoly material constantly rubbing against the wall and all. I'm guessing guys using these aren't your everyday streetable cars?? what are the advantages, I guess higher strength and longer lasting seal for those super high power motors??
Old Mar 17, 2003 | 04:57 PM
MadMax92's Avatar
more power. and they are not hard on piston walls, at leasty not like you think, you will never see bad side effects from the rings. but they give you better compression.
Old Mar 17, 2003 | 05:23 PM
eric93SE's Avatar
I agree, the moly coating alows less resistance, and longer life (ie. compression).
Old Mar 17, 2003 | 10:45 PM
Jeff92se's Avatar
I'm needing a caw
You guys talking about CHROME MOLY rings or rings that have a moly coating? Two different things.
Old Mar 18, 2003 | 07:51 AM
Michael's Avatar
Back in a 3rd Gen.
I was talking about chrome rings (over plate chromium) which I was saying were a little harder on the walls than stock or some other rings and that may have just been in my head since the walls looked more worn thay I THOUGHT they should have been. It had good compression though so like I said it may have been in my head
It sounds like they are talking about just moly coated rings...some manufactures call it plasma-moly some call it dura-moly and there are a few others probably but I think they are all the same basic thing.
as far as "chromoly" rings go I think that a lot of people use that term for the chrome rings.
another thing to consider is that these coatings are only for the top ring.
Old Mar 18, 2003 | 09:51 AM
DA-MAX's Avatar
thats why I was confused in the beginning!
aw11power
Oct 10, 2021 04:57 AM
Apr 16, 2020 05:15 AM
trsandrew
Apr 8, 2016 06:45 PM
trsandrew
Oct 25, 2015 02:47 PM
jaydot901
Sep 29, 2015 01:18 PM
