Rear Decklid Removal?
The previous owner of my car was kind enough to (ugh) glue speaker grills to the decklid, and cut holes in it with a steak knife for the speakers to sit in..
As you can imagine, this looks like crap. I'm trying to get the decklid off to refabric it, and am having a little trouble. (Ok, I can't figure it out)
Any insight on this would be awesome. It's a 94 GXE w/3rd brake light.
Thx much.
- Chris
Thx much.
- Chris
Hoho... Checked the FAQs before posting, but obviously not deeply enough.
E. How do you remove the rear speakers / amp assembly?
I just removed one yesterday from the junk yard. It's the same procedure Matt D listed below. Just remove the the rear seat enough to lift the rear deck lid up around the speakers. There are three clips and three 8 mm bolts. I removed all three bolts and two clips. Then I went to the trunk and carefully pulled the speaker and amp assembly down. If you simply need to remove the speaker, that is even easier and can be done solely from the trunk. - /Bryan (91 SE), 6/16/01.
If yours is the same as my 89, you have to get them out from the top of the rear deck. You can pull up on the front edge of the back seat and remove it. Then there are 4 bolts holding the seat back rest in. Then you pop up the deck lid cover and voila. The clips holding the cover in are delicate so be as careful as possible. -Posted by Matt D (89 SE) on June 10, 2001.
Heh, ignore the noob.
The Frye
Sep 2, 2021 11:03 AM
doctorpullit
Sep 10, 2015 06:33 PM
