Does anyone have a FSM for a 90
Old Mar 18, 2003 | 08:43 AM
ocMax's Avatar
Fuel Injector Problem
Yesterday i pulled code 51 form my computer (fuel injector circuit). I have a 90 VG SE 5 speed. I called the dealership today and they said that means the reason my car is running crappy is there is a leak in one of my injectors and or my car is running rich. my question is. . . . could a fouled spark plug be causing this? what could be the possible fix beside taking it to nissan and paying 120 for "further diognostic checks". your help is appr epreciated
Old Mar 18, 2003 | 08:50 AM
Jeff92se's Avatar
I'm needing a caw
Ah.. the leaky injector is probably fouling the plug.
You have two choices:
1) Have a dealer or a local mechanic replace it for $xxx
2) Do it yourself.
Considering your question and it's format, I suggest 1)
Old Mar 18, 2003 | 09:04 AM
chris92's Avatar
Re: Fuel Injector Problem
Try a resistance check on the injectors. My '92 VG specs a resistance rating of around 12.5 ohms. (double check the manual) If any are higher or lower, you can replace them with new or rebuilt ones yourself. The cylinder with the fouled plug likely has the bad injector.
Old Mar 18, 2003 | 12:21 PM
ocMax's Avatar
Re: Re: Fuel Injector Problem
How do i go about checking the resistance i have a multimeter but where do i hook it up.
P.S. i just pulled my #5 plug. and it is SOAKING wet. How hard is it to replace the injector? to bad this didnt happen 2 days ago when i had everythin apart for my valve cover gaskets
Old Mar 18, 2003 | 12:28 PM
subs1000w's Avatar
on a ve you just discounect the injector plug and test the 2 pins on the injector the fsm says any where between 10 and 14 omhs is fine i have 3 that are at 12, 1 thats at 18 and 2 at 23 so i have 3 good and 3 bad im pretty sure its the same on a vg but the back 3 in a ve you have to go to a sub harnes to test
Old Mar 18, 2003 | 01:59 PM
ocMax's Avatar
Does anyone have a FSM for a 90 VG 5speed and if so could I borrow it/ or could you photo copy some stuff for me? I need to replace my #5 injector. thanks alot!
Old Mar 18, 2003 | 02:03 PM
Jeff92se's Avatar
I'm needing a caw
Re: Does anyone have a FSM for a 90
Try not to make new threads that you know are related to your original. I told you to go out and buy one already. Or at least buy Chiltons. The Chiltons is only about $15 for goodness sakes.
Old Mar 18, 2003 | 02:09 PM
ocMax's Avatar
Re: Re: Does anyone have a FSM for a 90
the haynes and chilton are crap and i dont think they cover replacing fuel injectors and if they do its not very detailed. sorry im just trying to save some money and avoid taking it into a shop for 600+
Old Mar 18, 2003 | 02:19 PM
Jeff92se's Avatar
I'm needing a caw
Re: Re: Re: Does anyone have a FSM for a 90
ebay or buy a new one for about $100. Even at that you will still save money. Plus all the FUTURE jobs you no doubt be doing
Old Mar 18, 2003 | 02:29 PM
«§»Craig B«§»'s Avatar
I heard there is a write-up for replacing the injectors in the VG already online
Old Mar 18, 2003 | 04:57 PM
ocMax's Avatar
yes. yes there is i just found it like 10 mins ago. thanks for all the help
Old Mar 19, 2003 | 05:08 AM
Turbo91max's Avatar
hey, its not too hard to replace an injector or injectors. you have to disconnect all th little hoses and wires from the top of the intake manifold and then at unbolt the top of the intake manifold and then, unbolt the middle-part of the intake manifold, then they are right there. just disconnect the wires and **** to them .. unbolt the bad injector or whatever.. and there you go. theres alittle more then just taht but that is basic idea. look at my homepage and you can see abunch of pictures that could help you .good luck
CorollaULEV
30
Aug 9, 2021 08:11 PM
James92SE
Oct 8, 2015 04:57 PM
The Wizard
24
Oct 1, 2015 08:47 PM
Colossus
Sep 9, 2015 05:46 AM
Turbobink
Aug 15, 2015 07:20 AM
