Engine Swap
There's the same, and then there's direct replacement. Aside from the intake there are some number of other differences. For instance, the oil filter is in different places. The key thing to find out is if the motor mounts are the same: if they are the newer motor will bolt in. I am not sure about all of the different engine sensors. If the sensors are different and/or wired different you might need the newer wiring harness and ECU. Another possibility would be to use the old intake, injectors, sensors, etc.
Sorry I can only point out some ot the issues, and not give a difinitive answer.
derekinthez
Nov 13, 2022 04:00 PM
fastcarny
Oct 6, 2015 10:42 AM
