A Different Tranny Problem
Old Mar 22, 2003 | 08:01 PM
decked2damax's Avatar
It's weird or maybe it is juts me not knowing what i'm tlaking about. When i turn O/D on my car will just rev to bout 5500 or 6000 RPM then go into gear. If i turn O/D off it will drive fine unless I give it a little to much gas then it will just rev out to 6000 Rpm again. Am I correct when i say i need a new tranny or a tranny rebuild. I just do not want to get ripped offf if i take it to the shop. Thanx alot guys.
Old Mar 23, 2003 | 04:00 AM
cany anyone help me?
Old Mar 23, 2003 | 01:32 PM
Someone Help Please
PLease i need ot know if i need to drop a new tranny in this thang or not thanx guys
Old Mar 24, 2003 | 08:52 AM
Cincy94Max's Avatar
We're going to need a little more info to go on that what you provided. Are you flooring the gas pedal when you drive? My auto doesn't shift at 6000 unless I'm flooring it. You might try to see if your throttle cable is too tight or getting stuck if you aren't flooring it and it's still going up to 6000 RPM. If your transmission is shifting at 6000 RPM while using minimal throttle, I would say there is a problem. Try to describe exactly what happens in a lot more detail and we'll see if we can help.
Old Mar 24, 2003 | 01:54 PM
Ok a lil more info hmmmm....
Ok it's weird as u can see from above. my car shift if i floor it it shifts at red line. but the weird thing is if i turn overdrive on it just revs out to Redline then it shifts. Then if i turn Overdrive off it is fine to drive. But it seems if i try to give it a lil to much gas it revs out and redloine and then shifts. So i slowly have to apply gas cuz once i give it a lil to much she just just jumps to 6000 Rpm
Old Mar 25, 2003 | 08:41 AM
Someone????
Help me please im dyin over here
Old Mar 26, 2003 | 10:52 AM
PLEASE!!!!!!!!!!!!!!!!!!!!1
Someone please help me i went to a couple diff shops and i think they all lyin to me
pktaske
May 6, 2016 07:49 AM
Socalstillen
Sep 20, 2015 11:46 PM
iamute
Sep 20, 2015 05:22 PM
pktaske
Sep 4, 2015 08:40 AM
Lowered_a33
Sep 1, 2015 07:49 PM
