Removing the weight in the trunk
Old Mar 24, 2003 | 01:58 PM
TightBlack97's Avatar
I have some subs and amp now but wondering if I should remove the weight thing that is in the trunk(right behind the seat that hump that sticks out some of you guys know what I am talking about. It is only in the GXE I believe because I believe the SE do not have them which doesnt make any since. Should I leave it or take it out so the back of the box will mount flush to the back seats.
Any suggestions?
I am about to get the Amp and Subs wired tomorrow morning at Hifi Buys/Tweeter??
Old Mar 24, 2003 | 02:01 PM
Matt93SE's Avatar
STFU n00b!
yup.. yank it out, but be sure to cover the holes over with something. they're directly above the gas tank, and it'll get a bit stinky back there if you don't cover the holes.
only thing it's there for is to help smooth the ride a bit and lower road noise. nothing wrong with removing it.
Old Mar 24, 2003 | 02:10 PM
With what
Thanks Matt,
Should i just put cardboard and tape over them.........I guess I need to go to the Automotive store. The Subs and amp will smooth it out enough it probably weeighs the same.
Old Mar 24, 2003 | 02:18 PM
Matt93SE's Avatar
STFU n00b!
you need something waterproof
at minimum use a sheet of ABS plastic or metal, then seal it with RTV silicone. nobody will ever see it back there anyway, so it doesn't matter how ugly it looks.
Old Mar 24, 2003 | 02:31 PM
class or home depot
I am going to be working on this all night. Sounds like a little project.
Old Mar 24, 2003 | 10:08 PM
Matt93SE's Avatar
STFU n00b!
Re: class or home depot
WTF? that's a 10 minute job.
Old Mar 24, 2003 | 10:15 PM
AscendantMax's Avatar
Re: Re: class or home depot
he maybe doing it reallllllly slow
Old Mar 24, 2003 | 10:22 PM
yeah it was but I didnt use metal or plastic I used some wood I found because the sheet of metal I bought from home depot was just too big. It got a little messy because I was using that GOOF stuff then I realized that right in front of my face the whole time in the garage was a tube of ATV silcone.
I was so excited I forgot to look at what it actaully was. But it worked well we will know in a couple of hours when I wake up to see if it is sealed good. But the box will make it disappear anyway
Old Mar 24, 2003 | 10:55 PM
Matt93SE's Avatar
STFU n00b!
wood + water = rotten wood. I told you to use something waterproof. which means something inorganic. not living.. that means plastic or metal...
Old Mar 25, 2003 | 04:26 AM
Well I dont think it is going to
Number one you cant put anything metal over those holes unless it is 2"x3" because of that sensor that sits over the gas tank. I could not find anything that size within the time I had The car is 14 years old and has no signs of rusts. Look at the pics on my homepage. I did my best with what I had so be it if it rots. The cover that sits over the spare is wood of some sort and it has not rotted out. Correct me if Im wrong I guess it is inorganic. I dont know how much longer I can stand this car not because of performance or reliability but because of not having A/C for the second straight summer(its been in the family since 1992).
Number Two big lessoned learn if it rots.
Old Mar 25, 2003 | 10:54 AM
Matt93SE's Avatar
STFU n00b!
the wood panel in the trunk does not go directly to the outside of the car. would you replace your sunroof or floorboard with a piece of wood? I didn't think so. the holes that the bolts go through on that metal weight go to the underside of the car. i.e. weather exposed...
also, what I was meaning was not to block everything with one large piece, but to cut 4 smaller pieces of metal and simply glue them over the holes. very simple, and takes about 10 minutes, with a minimum of parts or work.
Old Mar 25, 2003 | 11:10 AM
DanNY's Avatar
Ad·min·is·tra·tor
just weld a piece of steel/stainless steel on it...
hint: make sure the gas tank is full
REDinLV
Aug 15, 2024 12:30 AM
my03maxima
Jul 28, 2024 07:40 AM
user 11122324
42
Jul 18, 2022 03:35 PM
RealityCheck
Oct 2, 2015 06:34 PM
jaydot901
Sep 29, 2015 01:18 PM
