Turbo question
Old Mar 25, 2003 | 07:23 PM
dnas420's Avatar
Turbo question
i just happened to get 2 16g turbos , 2 intercoolers, bunch a tubing, polished blow off valve, and a boost controller today. I am curious if i should sell these or can i use them on a ve/vg? or would another car be better to add them to? ive never turboed anything so im new to this. please fill me in.
Old Mar 25, 2003 | 07:29 PM
Lordrandall's Avatar
www.google.com
Old Mar 25, 2003 | 08:26 PM
CandiMan's Avatar
Say Candyman 5 times
www.eBay.com
Hopefully you'll make a profit
Old Mar 25, 2003 | 09:34 PM
subs1000w's Avatar
way to small for a max
Old Mar 25, 2003 | 09:41 PM
DA-MAX's Avatar
Eat, sleep, and sh*t 2JZ
you have 2, so go twin turbo
Old Mar 25, 2003 | 10:40 PM
dnas420's Avatar
hmmmm
so you guys think i should sell these? also why is it to small for a maxima. its not like i need to be going mach 3. how much are they worth? one has a bad wastegate (you can use an external wastegate no biggie . but the rest is perfect. Also i know there is one vve turboed but he didnt get it working right from what i heard.
Old Mar 25, 2003 | 10:50 PM
DA-MAX's Avatar
Re: hmmmm
those are preferibly for a 2.0L motor...Maxima is 3.0....T3 and up is perfered turbo for a 3.0L motor. sell them to some DSM guys.
Old Mar 26, 2003 | 07:58 PM
subs1000w's Avatar
they might work for twin turbo but good luck fitting all that sh*t under your hood all the 4th and 5th gen guys use t3/t4 and straight t4 turbos and the people ive talked to say a t3/t4 might runout of breate at high rpms and the bigger the turbo the less it has to work witch means less heat which means more boost with out detination but it also means the turbo wont kick in untill about 2500rpms so there will be a little lag. a t3 will spool up very quick but is still to small and will be overworked and will run very hot which isnt good for it or your motor thats why there mainly used on 4 bangers
Old Mar 26, 2003 | 08:01 PM
DA-MAX's Avatar
huh?? how much power fo you plan to be pushing through the T3?? ....most T3 60 trims are good for 350-400 HP!
Old Mar 27, 2003 | 04:54 PM
subs1000w's Avatar
i have seen that figure before and am not going to disagree with you on it but the guy ive been working with latly has a civic that runs 12.5 with a t3/t4 on a built b16 and he talked to turbonetics about it and they said thats alittle on the small side for a max like i said it can put out the numbers but it would be working the turbo very hard which would produce unecisary heat and shorten the life of the turbo. the turbo kit for the 4th and 5th gen comes with a t4 and the people that desinged it proboly did there homework and desided that would be the best for the job
Old Mar 27, 2003 | 05:09 PM
DA-MAX's Avatar
I agree, but a clipped T3 would probably work just as good. Ray Hall has been doing "their homework" a lot longer than the 4th gen guys and optimal turbo for a 3.0L motor is T3 w/ ~.63 AR according to them. I'm just saying optimal not making more power. of course a T3/T4 with the right wheel would make more power and come in sooner.
Old Mar 27, 2003 | 09:24 PM
JESSE93SE's Avatar
16g is just fine
i know alot of guys with dsm's running around on 16g's.
they seem to like them alot, and they work well on those cars.
i do know also that the first gen 300zx used a single t-3 and was capable of holding around 12psi .
a 16g will be fine for a vg motor running 9:0 commpression as they
could possably run 10+psi. for the ve motors, no more than 5-7psi would be recomended with the 10:1.
for a little boost, a 16g would be a good match, and still keep reliablity to some extent.
just my 2 cents
jesse
Old Mar 27, 2003 | 09:33 PM
DA-MAX's Avatar
Re: 16g is just fine
the 10:1 VQs have shown capability of running up to and around 11psi with no trouble ....why couldn't a similar mialage VE do the same??
and you can't really compare turbo output of a 2.0L motor with that of a 3.0...saying "they seem to like them alot, and they work well on those cars." is a broad statement and apples to oranges.
litch
123
Jan 4, 2024 07:01 PM
aw11power
Oct 10, 2021 04:57 AM
Unclejunebug
Apr 2, 2016 05:42 AM
09maxshawn11
Sep 30, 2015 10:28 AM
