Throwout bearing
Old Mar 25, 2003 | 09:35 PM
lophix's Avatar
Throwout bearing
Hey guys...
sorry to ask this but search is down and i'm kinda sorta really broke so no donating for now....
on my way to school today, i heard a weird sound coming from the tranny section while i was on the freeway. It sounded like a slight rough spinning sound which i kinda figured was the throwout bearing....unfortunately i dont know what it sounds like when its going out. It sounded only when I was in gear. I asked a second opinion of a friend of mine and of my mechanic and they both said it sounded like my throwout bearing was out. Is this normal? Should I get him to replace the clutch and p plate while in there? He said he could do the throwout bearing for 250. I asked him if he could change my clutch while he was in there and he said yeah he could do everything for 250. good deal or rape? what else should get done while he's in there?
thanks for the info.
Old Mar 25, 2003 | 09:40 PM
Matt93SE's Avatar
STFU n00b!
that's not too bad for the labor price.. about average.
might as well get the clutch replaced while you're in there, because the throwout bearing is a part of the clutch job.
btw, I've got a brand new OEM TO bearing in a box somewhere in the garage if you want it. I'll make you a deal on it.
Old Mar 25, 2003 | 09:45 PM
lophix's Avatar
yeesh!that was quick!!long time no speak. i was checking out nopionline and they had the centerforce clutch for 230 or so but didnt say if it came with the bearing...there was also a gd on exedy or sumpth like that...which do you have and which would you recommend I get? any difference b/w bearings?
Old Mar 25, 2003 | 09:56 PM
Matt93SE's Avatar
STFU n00b!
DO NOT get a centerforce. I've heard nothing but bad about them.
Supposedly Exedy is the same as the ACT, but I have no real proof. I'm running a LuK clutch, and you felt it. it'll grab good, but the pedal isn't nearly as heavy as the ACT.
get either the ACT, Exedy, or LuK. stay away from centerforce.
with any clutch BUT the LuK, you'll need a T/O bearing. the LuK comes with it's own.
Old Mar 25, 2003 | 10:05 PM
lophix's Avatar
how about I come over to Tulsa and we do a quick clutch install for a fraction?
oh and where can i get the luk from? I dont want to snap my leg in two when changing gears.
Old Mar 26, 2003 | 04:31 AM
Matt93SE's Avatar
STFU n00b!
I got mine from the local tranny shop. shop around online for it, they're out there. (google is your friend!)
I have ZERO time for clutch jobs! I can't even change my oil right now I'm so busy!
Old Mar 26, 2003 | 09:07 AM
DaBoxSE's Avatar
You should probably jump on this then!
http://forums.maxima.org/showthread....hreadid=192897
Old Mar 26, 2003 | 10:32 AM
lophix's Avatar
i believe that deal's ended, unless i'm wrong.....i think this will be the perfect time for me to do my mounts...mmmm finally.
Old Mar 26, 2003 | 11:03 AM
KuanSpeed's Avatar
"Supposedly Exedy is the same as the ACT, but I have no real proof. I'm running a LuK clutch, and you felt it. it'll grab good, but the pedal isn't nearly as heavy as the ACT."
According to a friend, and before I installed my ACT clutch, I took a look at the clutch and it has an exedy tag on it. According to my friend, ACT uses exedy stuff.
H
Old Mar 26, 2003 | 11:06 AM
lophix's Avatar
"According to a friend, and before I installed my ACT clutch, I took a look at the clutch and it has an exedy tag on it. According to my friend, ACT uses exedy stuff."
thanks for the info....now where can i get either for less than 3bills?
Old Mar 26, 2003 | 11:08 AM
Jeff92se's Avatar
I'm needing a caw
Probably for the clutch DISC. But alot of the holding power is at the pressure plate.
H
Old Mar 26, 2003 | 12:41 PM
D-sta's Avatar
The clutch disc in the ACT kit is a modified exedy clutch disc. I wish I could of taken pictures of that.
Old Mar 26, 2003 | 02:08 PM
lophix's Avatar
woohoo! just paid for the exedy kit at the gd price. woohoo!!!
Old Mar 26, 2003 | 02:29 PM
Matt93SE's Avatar
STFU n00b!
Really? my clutch disc on my old ACT said UNISIA on it, not Exedy.. (or is it VISIUN?)
Same symbol as what was on my OE clutch disc when I pulled it off the car:
http://www.ee.utulsa.edu/~mblehm/pic...h/MVC-019S.JPG
Old Mar 26, 2003 | 02:40 PM
lophix's Avatar
from what i heard, act recycles the discs from other manufacturers like exedy....no confirmation on that though...
Old Mar 26, 2003 | 02:50 PM
James92SE's Avatar
2 VE's are better than one!
I took off my clutch and flywheel today (Centerforce and Stillen aka relabeled AASCO flywheel).
I'll have some pictures up soon of the 'quality' of Centerforce.
Old Mar 26, 2003 | 02:52 PM
lophix's Avatar
lol thanks for the heads up....do you guys recommend my getting the flywheel lightened while at it?
Old Mar 26, 2003 | 02:54 PM
D-sta's Avatar
I recommend the AASCO.
Old Mar 26, 2003 | 02:55 PM
lophix's Avatar
not bought...i mean lightening the stock wheel since it will probably have to be machined anyway....
Old Mar 26, 2003 | 02:58 PM
D-sta's Avatar
Matt did that, according to him he noticed that the rev was a bit quicker. But make sure the place you take it to knowns what they're doing. He took off 3lbs. I think.
Old Mar 26, 2003 | 03:05 PM
James92SE's Avatar
Or you could over-pay for the Stillen
How much does stock weigh?
My Stillen/AASCO shows 10 lbs on the scale
Old Mar 26, 2003 | 03:06 PM
Jeff92se's Avatar
I'm needing a caw
Damn noobies:
https://maxima.org/maxfaqs/sub_perfo...Performance_5a
D-sta's Avatar
stock weighs 24lbs and the AASCO weighs 12 exactly.
Old Mar 26, 2003 | 03:09 PM
James92SE's Avatar
Weird mine shows exactly 10 lbs on a couple different scales
Old Mar 26, 2003 | 03:11 PM
lophix's Avatar
dang....thats a lot of weight difference....$160 to get i lightened? might have to look at that.
Old Mar 26, 2003 | 03:14 PM
D-sta's Avatar
A lot of weight difference and a lot of difference on how the car revs also. I love it.
Old Mar 26, 2003 | 09:06 PM
Matt93SE's Avatar
STFU n00b!
No, I paid about $50 for it to be lightened.
Old Mar 26, 2003 | 09:24 PM
lophix's Avatar
wow even better...mmm..any particular precautions to be taken when lightening it?
Old Mar 26, 2003 | 09:42 PM
Matt93SE's Avatar
STFU n00b!
not really.. just make sure the shop isn't stupid. there's a large metal ring on the back, outer edge of the flywheel. that's what I had chopped off.
send them the pressure plate also so they can balance the whole thing as an assembly.
here's some pics for you to see what I did.
www.ee.utulsa.edu/~mblehm/pics/car/clutch
Old Mar 29, 2003 | 05:37 AM
Nighty93MaxSE's Avatar
I hadn't looked around enough to see any bad things about Centerforces w/ Maximas, so I bought a dual friction kit w/ the seperate T/O bearing.. so far, I love this clutch.. at very low engagement speeds, there is slight shudder, but I rarely am driving slow anyway The clutch will take all the heat I can give it. I may have trouble later, but 5k into it, I like it..
litch
123
Jan 4, 2024 07:01 PM
James92SE
142
Jan 2, 2024 09:23 AM
user 11122324
42
Jul 18, 2022 03:35 PM
220k+ A32
25
Oct 3, 2015 09:09 PM
Andy29
Sep 29, 2015 05:32 AM
