Idling higher than normal
Old Mar 27, 2003 | 02:31 PM
naveed1966's Avatar
When I stopped my 92 Maxima GXE after driving it. The idling / tacometer goes over 1500 rpm. What would be the reason. - Thanks
Old Mar 27, 2003 | 04:10 PM
tafan321's Avatar
mine does that too , but only when i very first start it when its cold ... i've been told its normal for it to do that , but not quite sure about yours
Old Mar 27, 2003 | 06:06 PM
eric93SE's Avatar
tafan321: your conditions are very normal
naveed1966: Does the tach stay at 1500? or does it drop very slowly to a normal idle?
Old Mar 27, 2003 | 06:26 PM
tafan321's Avatar
Originally posted by tafan321
its normal for it to do that..
...didn't know that... thanks!
Old Mar 27, 2003 | 06:32 PM
naveed1966's Avatar
Idling
I was being impatient. I wait for it to drop for a good 2 minute and then I left. At least it stays at 1500rpm for couple of minutes. I will test it tomorrow.
Old Mar 29, 2003 | 06:32 PM
jkmay01's Avatar
Lil 8
Re: Idling
had the same prob with mine at one point could either be your throttle body sensor or your water temperature sensor. The water sensor measures the temp of the coolant, when the engine is cold of course the coolant is also, so when the coolant reaches the proper temp it sends a signal to reduce the idle speed. Check on the throttle body also. If it is faulty it may be letting too much air into the combustion chamber dont quote me on the location but too much air and the car thinks that you are pressing on the throttle. Let me know if that helps? I know if I am wrong I will be corrected.
Miket2006
Mar 1, 2021 03:55 AM
Unclejunebug
Apr 2, 2016 05:42 AM
salty318
Sep 29, 2015 01:21 PM
salty318
Sep 28, 2015 07:22 PM
